Will this rad keep my motor cool?
Old Feb 20, 2001 | 01:55 AM
GOLD85's Avatar
i picked up a IROC aluminum rad with twin eletrics. would this keep a 400HP 400 cool in the summer time. i paid $120 canadian for this set up aboot $90 US. is that an OK price. are IROC and GTA rads the same. Also it came from a 305 IROC if that makes a dif
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Old Feb 20, 2001 | 02:10 AM
burnoutrpm's Avatar
the rads are all the same no matter what year 3rd gen you have.. all plastic tank crap!! it could cool it though!?? with the dual fans! but, it might not cool good hp really good!! 400 sbc huh??? like you alrady my man!! the 400's are a prob to cool already, so, i say no way after all are the heads steam ported?? shouldnt ask thats a gimme. but with a 4000 no!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 20, 2001 | 05:51 AM
BTS88IROC's Avatar
I think with a 400hp 400 you would probably want to get an aluminum radiator from be cool or something and maybe keep the dual fan setup, that would be your best bet. Like already said those 400 do already have cooling problems.
Old Feb 20, 2001 | 08:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There are other things that have as much impact, or more, on the cooling system's performance, compared to the radiator. Run a 75-25 water-AF mix, a good water pump (NOT a stock one from GM or anywhere else), run enough timing advance and correct fuel mixture, use the correct head gasket with steam holes, keep it clean and scale free inside, keep it free of leaves and debris on the outside, make sure your lower air dam is intact.
I have had a 400 in my 83 for about 10 years now. I have a stock IROC radiator with the aluminum core and plastic tanks (which seems to cool better than the much heavier brass one it came with) and the stock HO single electric fan; I lived in the deep South until a few months ago and ran tha air conditioner non-stop for months at a time in 90+ degree temps, even then it didn't overheat.
ICON Motorsports
Old Feb 21, 2001 | 01:08 AM
GOLD85's Avatar
hey RB83L69 what heads you have on your 400. what cam.is ther any way i could clean all the corosion and crap out of my rad my self or do i have to send it to a rad shop. r u just runnig disdeled water and coolent. do you recomed that water less coolent.basicly i want to know what your cooling system consist of. thanx
R.I.P #3
Old Feb 21, 2001 | 08:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have 186 heads.
My cooling system consists of:
    Certainly nothing magical or out of the ordinary there. I would like to upgrade the fan but have never gotten around to hunting down a good dual fan setup, or a good aftermarket one. I would also like to get a control head for the A/C out of a later model car, that has provisions for vacuum for a heater control valve. As it is, the 83 cooling system flows water through the heater core 100% of the time, which of course bypasses the radiator and recirculates hot water right back into the cool water return from the radiator. So there are still a couple of improvements I could easily make if I got motivated enough.
    ICON Motorsports
    91 rally sport
    22
    Apr 5, 2016 05:06 PM
    fbirdroller
    Sep 2, 2015 10:27 PM
    TheExaminer
    Aug 26, 2015 04:59 PM
    TheExaminer
    Aug 19, 2015 10:07 PM
    Leggman1
    Aug 6, 2015 04:15 AM
