Overcharged Battery possible ???
Old Feb 18, 2001 | 12:09 AM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Transmission: 6 Speed
I noticed tonight that my dash lights were strong as ever, when I looked at my battery gauge, I noticed that it was in the red for a few seconds...then it dropped and went very close to red again. So I turned on everything. Stereo, lights, rear defogger, wipers....etc and it went down. I just changed my altenator again about 2 weeks ago, and well.....the battery has been dead now 4-5 times over the past 2 years. I never replaced it and well...could this be the problem or wrong alt.
Thanks people.
John
Brakes.......In My Dreams They.....DO NOT exist !!!
Old Feb 18, 2001 | 02:18 AM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by cruise12:
Thanks people.
John
</font>
what do you drive?
You could have a bad battery or voltage regulator.
Old Feb 18, 2001 | 05:38 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Well the voltage regulator is built into the alternator, and since its new, chances are its good. My guess would be that your battery is messed up. Usually after you run them dead a couple of times, they wont hold a charge anymore, or they may work funny like yours is. I would get autozone to test your battery and go from there.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 18, 2001 | 08:31 AM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
I drive a 92' Heritgae edtn. RS Camaro with ughhhh...a ...a...V6
I wish I had a v8 in it. oh well......the next one.
And like I said the alt. was installed just about 2 weeks ago. So maybe, it might be the stupid battery.....I will take it to the local store and have them check it out. Thanks guys.
John
[This message has been edited by cruise12 (edited February 18, 2001).]
Old Feb 18, 2001 | 09:44 AM
The ODB's Avatar
Don't trust Auto-Zone to test a battery.
He is right about killing batteries. Once you really kill them and coat the plates they are never the same and can act flakey. Just try another battery to see if the problem goes away. If so then buy a new battery.
Old Feb 21, 2001 | 08:31 PM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Hey guys, what's up. Just to let everyone know it actually turned out to be my freakin altenator again. The good thing is I did not have to pay for another one. They replaced it for free..whew !!!
On the way home the battery went basically dead again and I power braked the car home to smell rubber burning. The back of the main power to the alt. caught a small fire and the wires and bolts fused togther...nice huh !! I ended up replacing the metal connection and wire to the back of the alt. and heat shrinking the plastic round the wire to prevent corrosion. It better not catch fire again. Thanks for all your input and I bought a new battery
I had it tested and it was in battery heavan. Later guys.
John
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
