lt4 springs on l98 vette heads
Old Mar 17, 2004 | 11:02 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
Im wondering if the shims used for the lt4 springs will correctly fit around the guide on a pair of aluminum L98 heads
Do the guides need to be cut down to clear .525" lift on these?
thanks
Old Mar 18, 2004 | 04:51 AM
ede's Avatar
ede
shims are pretty much universal fit, only differance is the OD. you need to check clearances to know if you have too much lift or not.
Old Mar 18, 2004 | 07:55 PM
Car: 88 gmc 1500
Engine: 496
Sorry i should have been more specific. Im not talking about just the flat shims im talking about these
http://sdpc2000.com/cart.asp?action=...d=962&pid=8338
so will that shim fit a aluminum l98 head?
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
