air pump\smog pump stupid question?
Old Feb 21, 2001 | 04:51 PM
410GEARRATIO's Avatar
If i remove the air\smog pump can i still keep my air conditioner and heater??
thanks
jon
92 RS CAMARO, 305 TBI, 700R4
MODS: 14X3 OPEN ELEMENT AIR FILTER
UNDERDRIVE PULLEYS, HYPERTECH STAGE II CHIP
160 THERMOSTAT, 160 FAN SWITCH, GUTTED CAT(WITH TURN DOWN EXHAUST AT REAR END)
AND 4:10 GEAR RATIO..
Old Feb 21, 2001 | 04:55 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I removed the belt running it and the AC and heater worked fine.
Hope i helped
oop, you have a 92? don't they have serpintine belt systems? I have a 1986 with the older V-belt setup, so it was easy for me to drop the belt.
[This message has been edited by Christos (edited February 21, 2001).]
Old Feb 21, 2001 | 05:01 PM
thanks... so do you think i can leave the belt off permanently??
Old Feb 21, 2001 | 05:33 PM
82RECAROTA's Avatar
Old Feb 21, 2001 | 11:15 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Christos is right, a 92 does have a serpentine setup. Meaning that you can't just remove the belt. But you can still remove the air pump. I believe there is an article somewhere on this webpage that tells how to do it by getting a shorter belt and rerouting it. Removing the pump won't gain you much horsepower, and it could cause a problem passing emissions, especially since one look under the hood will reveal a disabled emissions system. But I went ahead and took the air pump off my 91 just because it helped to clean up the engine bay. It's a lot easier to change those sparkies now. Other than passing emissions, I don't see any adverse effects of removing the pump. Mine's been gone for two years, and I haven't had a problem.
Old Feb 22, 2001 | 09:21 AM
84TransAm's Avatar
The only problem it may cause later is to clog the catalytic converter. You will notice a major power loss. Headers will possibly glow red if the engine is left running. Just as a precaution, go ahead and gut the catalytic converter. More info on how to do this in Exhaust section.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Feb 22, 2001 | 12:42 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A properly running engine does not need the AIR pump. My 83 GP with CCCS passed dyno and idle e-tests with no air pump.
You could potentially clog the cat if you do too much short trip driving, as in those situations, fuel can get 'stuck' in the cats beds, then later on when it gets to full operating temperature the fuel burns melting the cat.
I do agree with the others, removing the AIR pump looking for HP isn't the way to go. Removing the AIR pump to have one less piece of **** in your way when you work on your car is.
...ed
Old Feb 22, 2001 | 04:42 PM
thanks guys i dont have a problem with emissions passing my uncle does it for me and wont even look at the car, as for the cat its been gutted since i got the car..
jon
mods: 14x3 open element air filter,
underdrive pulleys,hypertech stage 2, 160 thermo, 160 switch, gutted cat and of course 4:10 gears
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
gta power
Aug 13, 2015 06:15 AM
