engine goes up to 4000 rpm at start up
Old Mar 21, 2004 | 08:30 PM
fast86z's Avatar
Car: 1984 Pontiac Trans Am
I just finished putting my 305 back together. We rebuilt the carb and took out the distributor. When we start the car up it automatically revved up to 4000 rpm, so i immediately shut down the car. The fuel pump is pumping right once you turn the key on. Why is this happening? Could it be because it is receiving too much fuel, timing on engine is off since distributor was out, or carb isn't working right?
Old Mar 21, 2004 | 10:02 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Is your throttle cable binding somewhere?
Old Mar 21, 2004 | 10:38 PM
1986ROC's Avatar
Car: 1994 Pontiac Trans Am
Transmission: auto, but i want a T56
Did you check the idle adjuster screw? If you rubuilt the carb, and cleaned everything up, you probably had this screw off. Maybe when you put it on, you screwed it in too far.
Old Mar 22, 2004 | 03:30 PM
fast86z's Avatar
ya, ill try to see if thats it tonight, ill let you know what happens
Old Mar 22, 2004 | 03:40 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I had a similar problem when I installed my Edelbrock Performer Intake. I forgot to put on the correct carb base gasket (with 4 holes in it) under the Q-Jet and as soon as i started the car it immediately went up to 3500 rpm and sat there. It is probably unlikely unless you also changed the intake manifold though.
Old Mar 22, 2004 | 04:35 PM
fast86z's Avatar
No, I didn't put a new intake manifold on it, I did replace the old base gasket, but the new one that I put on is the same design and everything as the old one.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
