Alternator Squeeling?
Car: 99 Formula
Axle/Gears: 342
I think my alternator is making a squeeling noise, which means that it is charging the battery right. Recently I had charged my old battery about 10 times, this due to changing the cam and the car would only turn over. So I figured that it was time to just replace the battery anyway, but now it seems that my alternator is making a noise, is it just recharging itself or is it going bad. It happens worst when I have my lights and heat on, but eventually goes away. Any ideas?
Car: C1500
What does your gauge read?
Are you sure it isn't the AC compressor? On my cavalier it squeeled for over a year and the whole time I figured that it was the alternator bearings. I finally got brave enough to take the alternator apart and look, it looked fine. That's when I found out it was the AC compressor.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-vinyl security shade, velcro t-top bag
*****Possible summer '01 mods*****
Dual Snorkle, Auburn Posi, Keyless Entry, Wonder Bar from my IROC, 4th gen seats, T/A tail lights
http://www.geocities.com/krt80/
-180 degree stat
-Hooker Cat-Back
Car: 99 Formula
Axle/Gears: 342
I took the ac off the car. My volt meter will go below 13 sometimes, when it makes the noise, but then again, ever since I have had the car it has done that but never made the squealing noise
Car: 99 Formula
Axle/Gears: 342
That might be my problem, it takes a 5 groove belt, and the auto store only had a 4 groove in stock.
Car: 1986 Firebird
Engine: 2.8 V6
You put a 4-groove belt onto a 5-groove pulley?
I know with my '86 alternator, GM didn't design it too well to stay cool, so the bearings overheat and die after a while. My last alternator was squealing like crazy and actually throwing sparks out of the housing!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
raymondandretti
Sep 27, 2015 06:43 PM
