pulley and EGR question
Old Mar 23, 2004 | 01:17 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Im finishing up my new exhaust and was considering thorwing an underdrive pulley on there because i've got two weeks before i can get the car out so why not. I would like an aluminum one but if i cant find one at a good price I'll get the steel one for $50. Anyone know where i can get an aluminum underdrive crank pulley for about that price?
I'd also need a new serpentine belt, one for the smaller pulley and a removed smog pump, if anyone knows the length that would be great, but if you dont how do you measure the length? I was going to use a string, but do you do it with the tension pulley up or down?
I've been throwing EGR codes for about a year now, since i believe this makes my engine run richer (i think) and i dont want to foul out the new plugs im throwing in, i thought i'd replace that. Anyone know where you can buy an EGR valve cheap? Im checking summit, jegs, and GM parts direct now, if you know of others please share.
thanks,
-chuck
Old Mar 23, 2004 | 02:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will have better luck here with the pulley. As for the EGR just go to your local parts store. It is not worth it to have one shipped to you. That should cure your problem.
Old Mar 23, 2004 | 03:49 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
yea, wasnt sure where to put it. Actually local auto parts stores want nearly $80 for it. GM parts direct only wants $40 for it. What other online stores are there?
-chuck
Old Mar 23, 2004 | 03:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
-chuck
It is hard to beat GM PD. They are really cheap. You will pay a bit for shipping but it is sually still really cheap. I would just go with that $40 one you found.
Old Mar 23, 2004 | 08:39 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Is this thing that hard to install? anyone know where i can get a cheap aluminum underdrive crank pulley? Will a LT1 pulley fit my car? it seems they are cheaper.
-chuck
Old Mar 23, 2004 | 09:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
-chuck
A pulley is easy to install and is only a couple of bolts. An LT1 pulley will not work.
Old Mar 23, 2004 | 09:32 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Don't forget that the crank pulley usually comes paired with a smaller alternator pulley. If you don't do the alternator pulley as well then you stand a good chance of not driving the alternator fast enough to support your car and keep the battery fully charged. Been there and done that I'm afraid to admit.
--- Vern
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
egr- autozone
under drive crank pulleys -http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2116&prmenbr=361
i don't think you will be able to find them much cheaper then that
as far as the belt goes i have a 970k6 on my car right not but all i have is the smog pump delt i don't know if you have ot get a smaller belt for underdrive crank pulleys.
Old Mar 23, 2004 | 09:42 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
yea, autozone is like twice as much as GM PD, oh well, i thought a part as generic as an EGR valve would be cheaper there too, then i wouldnt have to deal w/ shipping, and waiting, and what not but aparently not.
how do you measure the length that the belt will need to be? tensioner up or down?
mdtoren
Aug 23, 2015 12:52 PM
Navy8125
Aug 22, 2015 07:13 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
