How do I adjust the IAC?
Old Mar 25, 2004 | 08:39 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
How do I adjust the IAC on my car? Where is it located? Id like to try adjusting this but I dont nkow anythign about it.
Old Mar 25, 2004 | 10:06 PM
Vader's Avatar
Apparently, you've been misinformed. The IAC is NOT adjustable. The IAC pintle position is controlled solely by the ECM.
Old Mar 26, 2004 | 07:38 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Vader, what about this?
camaro_V6_Tuner, do you mean adjusting idle speed via the IAC?
Old Mar 26, 2004 | 08:34 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Vader, aren't you referring to the MCS that is controlled by the ECM. the IAC is the big screw on the top front of the Q-jet that you adjust the Idle air to get a 50% dwell. If it has never been changed there is usually a metal cap rivited on top of it.
phil
Old Mar 26, 2004 | 09:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Might be a good idea if you told everybody what kind of car you're working on.....
Old Mar 26, 2004 | 09:50 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Good point!
Old Mar 26, 2004 | 12:23 PM
Vader's Avatar
Doesn't matter. (Nice copy of my article, BTW. )
And on your E4ME, that isn't an "IAC" It's a mixture solenoid position adjustment, or "MC" solenoid adjustment. There are also lean and rich stops that need to be checked/adjusted in association with that screw.
The procedure for adjusting the MC is significantly different than the one linked.
Old Mar 26, 2004 | 02:57 PM
Axle/Gears: 4.10
sorry about that....its a 87 camaro v6 multiport
Old Mar 27, 2004 | 11:46 AM
Vader's Avatar
Yeah - I presumed that from your original post and name. The information is still the same. The only "adjustment" of the IAC is to set the pintle length when installing a replacement IAC, and that is primarily to prevent damage to the IAC pintle on installation.
You can force the V6 ECMs to "relearn" the IAC position without touching the stepper motor (IAC), or be patient and it will learn it eventually.
Backing up a step or two, why exactly do you feel you need to "adjust" the IAC? Are you experiencing idle problems?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
