problems with my daily driver.........(little long)
Old Feb 23, 2001 | 09:04 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
1991 buick century w/ 3.3l v6 125000 miles
the problem started yesterday after work. i as on my way home when i noticed i was low on gas(just under 1/4 tank) so i pull in and throw the last five bucks i had in it(93 octane like i always use) well when i started the car and put it in gear i there is now a hesitation whhen i give it 1/8 to 1/4 throttle, any ohter throttle position and the car runs fine. it doesnt do it in neutral. i also got up to speed(45mph or so) and downshifted into 2nd(its a 3 speed auto) and when i would give it 1/8to1/4 throttle there was no hesitation. it only seems to happen when the car is in first or third. Im thinking that its the tranny and that it is having trouble engaging. i checked the tranny fluid and it was fine. the plugs are only about 2000 miles old and the oil and filter were changed about 800 miles ago. what do you think could be the problem.
thanks in advance
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS SUCK
Old Feb 23, 2001 | 12:18 PM
Axle/Gears: 3:08
just movin it up
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Old Feb 24, 2001 | 01:21 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
sounds like maybe just bad gas. Is that where you usually buy gas? What state do you live in? If it's Indiana or one of four other states (can't remember) the octane regulations for the stations there are NOT enforced - i.e. all octanes may be 87.
"We lost Dale. This isn't fun anymore"
R.I.P. #3
Old Feb 25, 2001 | 10:54 PM
Axle/Gears: 3:08
I live in florida and its int eh same place i always get gas.. yesterday i changed the plugs and wires and it still made no diff.. i filled it up with 93 octane like i always do and it still runs like i described and other ideas would the timing being off cause this(i havent checked the timing yet)
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
