Should SES light come on if car stalls?
Old Feb 26, 2001 | 08:36 PM
JETHROIROC's Avatar
I read somewhere on this board that the SES light should come on if the engine stalls, but mine never does. It's a '90 350 TPI IROC, if that helps any. Is the ECM screwed if it doesn't come on? Thanks guys.
Old Feb 26, 2001 | 08:45 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Does it come on when you first turn the key to the "on" position?? (not cranking)
If not, the bulb might be missing.
I've seen that when the light keeps coming on, some people will not pay to fix the problem, they just pull the bulb.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Feb 26, 2001 | 09:03 PM
JETHROIROC's Avatar
Yeah, it comes on then and it flashes a 12 when I jumper A&B terminals too. Just not when it stalls. Should it? Thanks man.
Old Feb 26, 2001 | 09:44 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Mine works correctly and when it used to stall the light didn't come on. I'm not sure if it's supposed to though. My guess would be no.
Old Feb 26, 2001 | 10:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
All my lights come on when the car stalls
Old Feb 26, 2001 | 10:57 PM
JETHROIROC's Avatar
I wonder if my ECM is screwed up?
Old Oct 24, 2007 | 12:25 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Should SES light come on if car stalls?
the only time my ses come's on when my car stalls is if it is throwing a code, if the problem doesnt throw a code the light doesnt come on, thats on my 89' RS
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Omega
Aug 10, 2015 12:46 PM
