"Check Engine" light
Old Mar 31, 2004 | 05:16 PM
Chuck's Avatar
Mystery: A guy put an amp and sub in my '89 RS. When
I drove it - after about 5 minutes the "check engine" light
blinked on and off at irregular intervals.
A week later, I still have the problem. Engine seems to be
running ok. At 2500 RPM light blinks on 1 second, off one second,
etc. Any ideas????
Old Mar 31, 2004 | 05:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What code is it throwing. That will tell you right away.
Old Mar 31, 2004 | 10:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
On and off? Sounds like the ECM got locked into key on-engine on diagnostic mode. If I remember right, it's actually spitting out a rough approximation of your a/f ratio. On and off equal amounts = normal mixture. Longer on than off is rich, and longer off than on is lean, or something like that. Make sure nothing's been messed with at your ALDL connector....
chazman
Aug 28, 2018 03:25 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
