Grinding like noise when AC is on
Old Mar 31, 2004 | 05:53 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
Any of you had this problem before? I didn't really notice it until I went outside of my car when the A/C was on. is this normal at all?
Old Mar 31, 2004 | 06:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No, sounds like the compressor has wasted itself. Make sure the noise is actually coming from the compressor and not some other part on the belt line. If it is the compessor, youll probably need a new compressor and, I think, a new condensor since I dont think the shrapnel and debris can be flushed out after the pump craps out.
Old Mar 31, 2004 | 07:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds like something is wasted on your accessory bracket.
Old Apr 1, 2004 | 04:00 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
How bad is the grinding noise? Does it just sound like extra drag on the belt? Some times with an older belt the A/C will create too much drag and the belt will start slipping. Just a thought...
Bruce (90RS305)
Old Apr 10, 2004 | 05:46 PM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
I had a similar problem before, what I did to fix it was take off the tensioner pulley and clean it out as best you can. After you clean it, spray some wd-40 and you should be good to go.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
hdis2002
Sep 8, 2015 02:52 PM
Randomtask2
Sep 7, 2015 05:06 PM
