Lifter Removal--next question
Old Mar 1, 2001 | 02:38 PM
gruveb's Avatar
Car: 1989 IROC-1
OK, the weather has cleared up, it's warmer and I'm back on my 84 Z project. Now, these lifters are being very stubborn about being removed. Do I need to get the lifter removal tool suggested in the manual, or is there a better way?
Old Mar 1, 2001 | 03:04 PM
Guest
Guest
Posts: n/a
Assuming you arent reusing them... grab them with some pliers and see if you can get them out. Lifters get a coat of varnish near the bottom, and thats what prevents them from coming out. You can try spraying some solvent on them too, but you dont want to go too crazy with that if you arent tearing the whole engine down.
Old Mar 1, 2001 | 03:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you're changing the cam, just pull them up enough to clear the cam; then push them back down carefully while holding sometihng under there to catch them so they don't fall down into the lower part of the crankcase.
ICON Motorsports
Old Mar 1, 2001 | 03:12 PM
Guest
Guest
Posts: n/a
That reminds me...
I read in a magazine about using an old christmas paper cardboard tube or similar, and cutting the top open to catch the lifters. I dunno if that would work, but hey... sounds like a good idea.
Old Mar 1, 2001 | 03:15 PM
gruveb's Avatar
Car: 1989 IROC-1
I won't be resusing them. I just don't want to end up forcing anything, when you force something, unless you're very familiar with the way it works, it breaks.
I'll try the solvent and pliers.
Thanks again.
Old Mar 1, 2001 | 03:20 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by gruveb:
Thanks again.
</font>
You can grab the edge with some vice grips and turn the lifter side to side as you pull up. You may have to pull up, then push down, then pull up, over and over again to get them free.
Each time you pull up then push down, the lifter should come out of the bore a little bit more.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 1, 2001 | 03:55 PM
gruveb's Avatar
Car: 1989 IROC-1
So in another words, "hold your mouth right".
When I was a deisel mechanic, the big boss man would come in when you couldn't get something off or on to help. He'd usually get it done in a snap, and when asked how he did that so easily, he'd reply, "You gotta hold your mouth right."
Old Mar 1, 2001 | 04:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What madmax said is exactly the sort of thing I was talking about... as long as you can get all of them up out of there enough to allow the cam bearing journals to get past, they'll always go down even if they won't come up.
ICON Motorsports
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
