Spring and cam combination?
Old Mar 3, 2001 | 10:49 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
First of all is true that the ZZ3/ZZ4 camshaft is actually one in the same? Tell me if this combination will work ZZ3 camshaft with GM spring #1013458 in a stock but ported L98 heads. Will I have retainer to guide interference problems when using stock rocker arms? What is the best valve guide seals to install to get rid of blue puff when starting engine? I was told those spring are stock in a ZZ3 crate engine but have no way of knowing. Thanks for your help.
Old Mar 3, 2001 | 10:53 AM
The ODB's Avatar
depends on what retainers you are using.
tell you what, this will solve everything.
just have your guide bosses machined down for more clearance and get the positive style teflon seals installed. Then there's nothing to worry about on both counts.
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
