Why is my alternator get so da%& hot
Old Apr 4, 2004 | 10:16 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Maybe this is a stupid question but after puting in a TPI set up, i noticed after my car runs for awhile my alternator gets really hot, even my friend said something about it. I ran the part numbers and they were the same for TBI set ups and TPI set ups. Any ideas or is it just my imagintion???
Old Apr 4, 2004 | 11:27 PM
Vader's Avatar
Unless your electrical demand has increased significantly (and it should not have due only to a swap to TPI) the alternator should not be any hotter. You may have a coincidentally failing alternator, or inadequate cooling air flow.
Old Apr 4, 2004 | 11:46 PM
Vader's Avatar
Also, if you change the belt drive system, make certain the alternator is turning the correct direction. It will charge either way, but may not cool well is running backwards. The fan behind the drive sheave should be your guide.
Old Apr 5, 2004 | 06:59 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Also re-check the quality of your grounds.
Old Apr 5, 2004 | 09:10 PM
Car: 92'Camaro RS
Engine: a loud one
All good points for me to check out, thanks........Vader what would cause inadequate coolant airflow ? The motor only has about 14,000 mi on it ?
Old Apr 5, 2004 | 09:38 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
the alternator fan spinning the wrong direction as he indicated.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Thaney9
Oct 24, 2015 07:26 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
