What mod next? Help me decide
Old Apr 5, 2004 | 11:23 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I've got some cash to spend on the car, I was thinking...
k&n filter lid top 50.00
air/fuel meter and 02 sensor 100.00
carb calibration kit, 600 edelbrock 40.00
accel 300+ wires (have super stock now) 45.00
Does this sound like money well spent? I am running out of little things to do to the engine and I am pretty satisfied with the cars performance right now. Should I keep saving for a nice set of heads?
Old Apr 5, 2004 | 11:58 PM
3rdGenBlackBird's Avatar
By "filter lid top" do you mean those newer filters that sit on top of a reagular open element filter?
If your R/A hood is funtional and there's room for air to flow over the top (between the hood ceiling and filter top), then that'd probably be useful. If there isn't any room for air to flow over it anyway, it's probably a waste.
I'd get the carb kit and get tuning! I'd also skip the wires for now.
After that save for heads or exhaust.
Just my 2 cents.
Laters,
Scott
Old Apr 6, 2004 | 12:20 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What all is done to the car as it is?
Old Apr 6, 2004 | 12:33 AM
juggernaut_69's Avatar
Car: 87gta
Engine: dont know yet
Transmission: 700-r4 race prep
sounds like a start. Also dial in your timing
Old Apr 6, 2004 | 02:53 PM
1983Fbody's Avatar
Engine: 415
Scott,
The hood is functional and yes it is the filter lid that goes on top of the regular K&N filter. I can see how it would be a benefit after reading your post it makes more sense the engine would suck more cold air though the top vs. sucking from the sides and gathering more of the warm underhood air.
-1.5 roller rockers
-retrofit roller cam
-hyd. roller lifters
-noisy timing gears
-edelbrock headers, ypipe, and rpm catback with hooker tuned flow mufflers
-insulated fuel line, k&n 14x3"
-Accel wires, accel coil, accel hei module, advance kit springs and weights
-350 crate motor w/ported 58cc 305 heads
-holley mechanical fuel pump
-summit highflow h20 pump, be cool rad., very small flexfan
-rpm air gap, 600cfm carb
Elephantismo
Feb 13, 2019 12:51 AM
Fronzizzle
Feb 9, 2017 09:31 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
topteam54
Oct 6, 2015 12:21 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
