I.A.C counts
Old Mar 4, 2001 | 03:18 PM
Mike635's Avatar
I.A.C counts
What should your i.a.c counts be at idle? Was doing tune-up today,and using the x-ray scanner my counts at idle are zero.Is i.a.c. bad? The numbers rise in smooth fashion,looking at differant books i get conflicting information. Thanks Mike
Old Mar 4, 2001 | 05:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If I recall, when mine is warmed up, I get about 25 or so...if yours is at "0", could be due to the min idle set too high, or a vacuum leak, causing higher than normal idle conditions.
Old Mar 5, 2001 | 02:02 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Yep, that's right. If the minumum idle speed is set correctly and you have no vacuum leak, you should see about 25 counts in closed loop at idle.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 5, 2001 | 02:54 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, it depends on the general tune of your engine and how rich the car is running. I have made MASSIVE changes to my eprom to erraticate the excessive rich condition that GM puts in the eprom. Now I run 128/128 perfect and my IAC sits around 70 and idles perfect.
There are too many variables to say what the perfect IAC number is; it is dependent on all those factors in getting the proper number of "steps".
Also, different induction systems have different numbers. Get the idle smooth and let the engine tell you what IAC it wants. Even you ambient air temperature causes an effect if you have a relocated MAT.
antman89iroc
36
Jan 31, 2016 08:42 AM
gta892000
Sep 16, 2015 12:40 AM
kymmee
Sep 2, 2015 09:01 PM
Fox118
Sep 1, 2015 04:07 PM
Eric2ndGen
Aug 31, 2015 11:30 AM
