Stupid newb ?...again...
Car: 87 FireBird Formula
Engine: 305 4bbl
Since im new to this carb **** I am a bit confused...I went and bought an air cleaner to drop on top...Now...here comes the ?...There was a small hose connected to the front of the carb...some sort of vaccum i assume...wheres that go now?
also...the i think its the "smog vaccum" from the PCV on the passenger side...Used to go into the side of the cleaner...Now wheres it go? I believe there might be a cut out underneath the new cleaner but how the hell do i reroute it underneath since i already needed a 1" spacer and there still is hardly enough room...
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
The line your refering to that use to go into the air cleaner is your clean air intake for your PCV system, a simple push in style breather in place of the line would solve the problem.
gta892000
09-16-2015 12:37 AM
