Vortec roller rockers on an L98??
Old Apr 16, 2004 | 02:40 AM
PerthZ28's Avatar
Powerhouse are selling Vortec long slot roller rockers in either 1.5 or 1.6 ratios for $89.95. Has anyone used these? They are self aligning - will they go on to an iron headed L98? How about valve cover clearance - I am using the centre bolt magnesium Vette valve covers.
Old May 4, 2004 | 09:57 AM
PerthZ28's Avatar
ttt
Old May 4, 2004 | 10:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no such thing as "Vortec" roller rockers. They're just using the "Vortec" buzzword.
I can't imagine roller rockers for $90. About the cheapest ones I've ever seen are the chinesium ones from places like CAT, for about twice that price. But I could be wrong.
Those are probably "roller tip", not "roller". At that cheap, they're probably also just stamped sheet metal. In which case, they're not worth the price.
Don't fall for the buzzword.
Old May 4, 2004 | 09:12 PM
PerthZ28's Avatar
Yeah you're right mate - I think they are just roller tipped stamped steel ones, but I was after the 1.6 ratio as much as anything...is there a better/cheaper option for getting the higher ratio?
Old May 4, 2004 | 09:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Comp makes roller tipped Magnum rockers that clear centerbolt valve covers and are offerered in the 1.6 ratio. <A HREF="http://store.summitracing.com/partdetail.asp?part=CCA%2D1418%2D16">CCA-1418-16</A>
What cam are you using at the momment?
Old May 5, 2004 | 09:01 AM
PerthZ28's Avatar
I just have the stock '88 350 cam [0.415" and 0.430" lift]. Because there seems to be only a minor benefit using 1.6 rockers, I don't want to spend up big on them - that's why the Powerhouse El Cheapos looked OK! I couldn't find a basic stamped 1.6 rocker that was self aligning either - does anyone else make them?
Old May 5, 2004 | 09:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't want a stamped rocker, if you're looking for any kind of performance increase. They are garbage.
Sheet metal rockers are weak. They bend. Different ones within a "set" bend different amounts. Therefore your valves don't all open the same.
The Comp 1400 series is about the least expensive ones (chinesium ones are "cheap", these others are inexpensive) that are reliable and give a consistent ratio. I'd also recommend those.
Old May 5, 2004 | 10:15 AM
ede's Avatar
ede
comp makes good stuff, only rockers i run are from comp.
Old May 17, 2004 | 04:05 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Yeah and the stock ones are stamped also and use a thinner material and many people are getting 150,000 + miles on them without any problems. So going to another stamped roller tip with a thicker gauge than stock, can be nothing but a good thing. If your not building a super high performance motor that revs over 7 grand I don't see the problem. Yeah there not the best but some people don't have the extra dollars for the best parts. If your just adding some bolt ons to a stock motor they are an upgrade from stock stamped rockers, and they will benefit your motor, even the least expensive ones are more accurate to there ratios and deflections than the stock rockers.
Old May 17, 2004 | 04:25 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Jegs sells proform full roller rockers that are self aligning. 179.99 I think. Just make sure you don't float the valves with them, LOL.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
