Identify the SPEED CONTROL gadget....?
Old Apr 16, 2004 | 01:06 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
What is this? What does it do? If it does anything does it create vaccumm? Should it click or move when hooked directly to a battery for testing? thx
Old Apr 16, 2004 | 01:17 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Cruise control servo. It controls the throttle setting when the cruise control is engaged. It uses vacuum pull the throttle open & but does not create any. It has no electrical components in it, so hooking it up to battery will have no effect on it.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is the vacuum control for your cruise control.
Old Apr 16, 2004 | 02:17 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
ok how does this pull the throttle cable if it doesnt create vacumm, what hose connects to it to supply it with vacumm
Old Apr 16, 2004 | 09:13 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
It does not create vacuum, it uses vacuum from either you TBI unit or your manifold (don't remember where it hook up to). The two hoses are vacuum hoses. Inside the unit is a diaphram. If your cruise control is not working and all else looks good, you may have a crack in the diaphram. Its very thin and can dry out.
Old Apr 16, 2004 | 10:01 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you have a 5.7L, I'm gonna assume you have TPI.. If you have TPI, there is a port on the side of the plenum that T's off to the HVAC and the Cruise control (there is a check valve that also serves as the "T")..
Old Apr 17, 2004 | 02:04 AM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
any pics of the split?
Old Apr 17, 2004 | 06:29 AM
thirdgen88's Avatar
Car: 1995 Corvette
This one shows it... It connects to that forward port on the plenum (the bigger one)...
Attached Thumbnails Identify the SPEED CONTROL gadget....?-map-sensor-removed.jpg
deracer
Apr 11, 2016 12:04 AM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Linson
Aug 21, 2015 02:12 PM
