Strange Problem, Wiring?
Old Apr 17, 2004 | 10:08 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My car had been running quite decently, when the other day I hit a lovely bump in the road, and the ecm fell from under the dash. Still ran fine. No biggie, I had to do work on the car this weekend.
I just now stuffed the ecm back under the dash, changed NOTHING else on the engine. Everything else I did was cleaning and suspension maintiance. Now my car runs extreamly rich.
I dropped the ecm again, swapped in a different one, still runs rich.
Would this indicate a funky ecm, or bad wiring?
Old Apr 17, 2004 | 01:57 PM
Vader's Avatar
I'd suggest you start by disconnecting the battery, unplug and reseat each of the ECM connectors a few times to help clean the contacts, and verify a good ground to the ECM.
Old Apr 17, 2004 | 07:47 PM
Dale's Avatar
Engine: 350 S-TPI
I've unplugged it a few times, even swapping ecms.
I'll check ground next time I'm working on it.
Old Apr 17, 2004 | 11:02 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Double check and make sure that none of the wires are loose from the connector. Try giving each wire a little tug just to make sure that they are tight. What the heck kind of bump did you hit to knock the ecm down? They must have some serious road problems down in AR.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Fronzizzle
Aug 17, 2015 02:52 PM
