souunds like im hitting rev limiter
Old Mar 9, 2001 | 12:04 AM
zee28's Avatar
Car: 86 iroc
but i dont have one.when I floor it (LG4) it takes off great,runs great,but right around 4800rpm and on it starts what sounds exactly like a rev-limiter.Most of the time its only for a second, and it goes right away when I let off just alittle.I recently put a accel module in,please dont tell me its that.it did make car run better,I swear.I have all computer controls and no codes.Most parts on my car are new or close(tune up items)and it does run great ,its just this.I am pretty sure it did it before the module was put in.no codes.valve?too big rods or hangers?timing?thanks
~mike~86 IROC-Z
Old Mar 9, 2001 | 02:18 AM
burnoutrpm's Avatar
did it do this before the module change??? well if so you know the problem... the accel unit!! it surely wouldnt start that all of the sudden!! try chngin back to the stock module and see if the problem quits if it does...well.. accel sucks anyway!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 9, 2001 | 07:46 AM
zee28's Avatar
Car: 86 iroc
first,I didnt ask for anyones thoughts on accel.If thier stuff is crap then they make more in 1 hour selling that crap then you make in a year.Just because you dont like somethng doesnt mean its crap,some have been brainwashed by these boards.Anyway it did it before the module swap.So I guess its some other crappy part.Need a answer to my question,dont care what anyone thinks of the parts im using.o,and i gues you noticed a gain in power by adding that msd,please.Its an ignition.
Old Mar 9, 2001 | 07:48 AM
zee28's Avatar
Car: 86 iroc
maybe I will get me a PROFORM module,LOL.
~mike~86 IROC-Z
Old Mar 9, 2001 | 08:51 AM
ede's Avatar
ede
play nice guys, no flame wars allowed.
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 09:15 AM
zee28's Avatar
Car: 86 iroc
your right ede.Its just everytime I ask something I dont get a reply but someone telling me the parts i bought are crap,or no good.I did say it did it before the module,but because the module is accel ,its that.I didnt buy the module to go fast,I bought it because I figured it was more reliable then a trak auto part.If im wrong then so be it.If i had asked the same question but not mentioned the accel module would someone still have said to check the module?Dont think so,the fact that I said accel got the response.I dont claim to have the best parts,or know whats best.And he may be right about the module,but unless he had one do this then I will look for something else causing this.If he said "I had a accel module do this" then it would be differant.Maybe I described the problem wrong,I guess it could be more like a backfire threw carb?Thanks and sorry for the attitude.
~mike~86 IROC-Z
Old Mar 9, 2001 | 10:35 AM
Blade's Avatar
Hey that MSD made a difference on my car. I dont know about actual ETs or HP, but throtle response is MUCH better. I love it :P
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 9, 2001 | 03:17 PM
Polecat's Avatar
Did you replace the coil or just the module. On stock HEI's, I know they run out of steam pretty quick.
Or, at WOT at that area, check fuel pressure. You may be loosing fuel pressure and it cuts out.
My brither-in-law added a mild 355 to his '82 Z28, and when he went to run it at the track, it would fall on it's face at higher RPM's due to loosing fuel pressure from the old stock pump.
Accel isn't that bad of stuff, but there is better and some worse IMHO.
Good luck and let us know what you find out.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
