Finally got my car running with LT4 HOT Cam, WOW!!!!!!!!!
Old Mar 8, 2001 | 10:57 PM
Dan87IROC-Z's Avatar
I finally got my car running and I took it out for the first time, and HOLY COW, the swap was well worth all the money I spent. I do agree that the car does need more intake and better heads, but its okay for now, I have my new rear end comming in this summer. The runs like hell from 3000 RPM up and the idle isn't all that bad, its noticeable, but not bad at all.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 8, 2001 | 11:07 PM
Mike92's Avatar
Awesome, that idle sounds neat. Did you notice any lose of low-end torque, or should I say How much did you notice, because I know you lost some Lowend with that cam.
92fb currently a TBI 305, (hold the laughter to a minimum). Going to be a 350 carb with 350HP and 400FT/Lbs.
Old Mar 9, 2001 | 02:58 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Glad to see that you got everything sorted out.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 9, 2001 | 03:04 PM
Biochem's Avatar
Car: 2002 SOM z28
Cool, I like to hear about success stories for a change!
BTW- why are you dumping the 9-bolt for a 10- bolt?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Mar 9, 2001 | 05:06 PM
Yes, I lost some low end power, nothing that is making me regret the swap, but there was some lost down low. I won't have a chance to take it down to Bandimere Speedway for about another month, but when I do I will post my time slips both before and after the cam change. The car has insane power from 3000+. I am getting rid of my 2.77 9 bolt because I am having a friend's dad built me a 10 bolt with 3.42s, all I have to buy is the ring and pinion set and the drum brakes. He's setting up the rear end (the 16th of his life) and is going to help me install it all at cost so thats good. I'm hoping with the new cam and new gears I will be running mid 14s up here (mid 13s at sea level).
L98 TPI 350 (5.7L)
Old Mar 9, 2001 | 05:34 PM
Mike89GTA's Avatar
I have the LT4 Hot Cam and it has so much torque it's almost hard to shift into first gear!! Don't worry about low end torque.. oh yea I have SLP 1 3/4 headers.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Mar 9, 2001 | 07:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Same here Mike. I can keep the tires lit to third gear. Its gonna be a problem at the track.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Old Mar 10, 2001 | 01:48 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Nice to hear that ya finally got it running, AND that it was worth the money. Seems like alot now days you don't hear a whole lot of people say it was worth their money.
Now ya'll got me wanting a bigger cam, hehe. Think i'll wait till i get the engine out this summer.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 10, 2001 | 03:04 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What are the specs of that cam?
Old Mar 10, 2001 | 04:48 PM
Vader's Avatar
Dan,
I went to a Comp profile that has a little more lift/duration than the LT4 "Hot" and noticed the same thing. The low end fell off a bit, but not badly. This might have been more due to the larger valves and head porting on mine than the cam profile. When I get around to the converter swap, the difference at low end won't matter, since low end won't exist any more. Your rear gearing should have a similar effect. Hold on to the reins.
But you're right - the difference from about 2,600 RPM on to ??? is worth any minor loss at low end. Like the little pink bunny, it keeps going, and going...
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 10, 2001 | 06:00 PM
I so wish I had the money now for new heads and/or a new intake parts. I am flat broke now and this new rear end is going to cost me about $350, which is still a bargin. Are there any mods I can do that are cheap that I haven't done yet that can help my car be faster with this new cam?
L98 TPI 350 (5.7L)
MustangBeater20
Oct 29, 2022 09:20 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
anesthes
Aug 8, 2015 09:37 PM
86Base
Aug 8, 2015 01:34 PM
