Fuel line fitting size on stock fuel pump..
Old Apr 20, 2004 | 10:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Anyone know exactly what size fitting goes into a stock carbuerated fuel pump??
I want to get a fittng that will screw into the fuel pump outlet and adapt to a -6 an steel braided hose. I know it looks bigger than 1/4 inch. I'm just guessing that it's 3/8 NPT - is that right??
- Thanks in advance for any assist!!
Old Apr 20, 2004 | 10:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The outlet should be a 3/8" inverted flare.
Old Apr 20, 2004 | 10:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Aeroquip P/N FCM-2108
Old Apr 20, 2004 | 11:59 AM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks for the help!
BUT : If it's 3/8th's then the part number you posted must be wrong Apeiron. Here's what Jeg's has it listed as:
023-FCM2108 Inverted Flare 5/8''-18 thread; -06 Hose Fitting
So just for further clarification, it is 3/8th's right??
Old Apr 20, 2004 | 12:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's definitely 3/8".
Seems like what I usually end up having to do, is to use a ¼" pipe junction as a transition.
Old Apr 20, 2004 | 01:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
This is for the mechanical pump, right? 3/8" inverted flare fittings have 5/8" - 18 threads.
Old Apr 20, 2004 | 05:49 PM
Confuzed1's Avatar
Car: 83Z28 HO
I went out and took another rough measurement, and you're right - it appears to be 5/8th's. Looks like the tubing size itself might be the 3/8th's part of the equation. I'll try the part you suggested.
Thanks again!
EDIT: And yeah, it's the stock mechanical I'm referring to.
Old Apr 20, 2004 | 05:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It is.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Linson
Aug 21, 2015 02:12 PM
AkDrifted
Aug 17, 2015 07:45 PM
