Changing fuel filter
Old Apr 16, 2004 | 01:52 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
How do I do this? I have a 92 305TBI if that makes any difference. I'm assuming it's as simple as taking out the old one, and putting the new one in? And how much fuel should I expect to come pouring down on my face?
Old Apr 16, 2004 | 02:54 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Well for my 87 GTA Trans Am, i disconnected the batter first, so the pressure from the fuel line dies down. Dont remember if i waited some time to take out the fuel filter, or went right at it. But anyways, thats gonna avoid have about 40 plus psi of fuel hitting your face if you disconnect the battery first.
Taking out the fuel filter, mine i just unbolted the 2 nuts on each side of the filter. They were tuff to come out, so i had to wd-40 them, and eventually loosen them out.
After that, just make sure you face the fuel filter the right way, there should be an arrow on it, showing which way the fuel flows in the filter. Then just bolt it back up, connect battery, and give it a test.
At first, the car might stutter or look like its gonna die, but thats probably cuz u got rid of the fuel pressure, but it should be back to normal in no time.
Anyways, it might be different on your car, since its 92 305TBI, but hope that helps.
P.S. Make sure you put a container or something to collect some of the fuel that will leak out. It shouldnt be alot, but there will be some.
Old Apr 16, 2004 | 04:30 PM
Car: 92 Camaro
It's the same as what you described, I just wanted to make sure there were no under laying complications. Would help if I had a full set of wrenches, out of all the wrenches I have, the only one missing is the 16mm that I need to get the filter out.
Old Apr 16, 2004 | 04:50 PM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
To bleed the pressure from the fuel lines without disconnecting the battery pull the fuse that goes to the fuel pump while the car is running. After a few seconds it should die and that assures you won't get sprayed in the face. then it's as simple as removing the old one and putting the new one in. Make sure the flow is in the correct direction though.
Old Apr 16, 2004 | 04:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
In addition to the above post, I would suggest that you use a shop towel around the schaeder valve to release any pressure in it if you have a TPI. I would also remove the cap from the fuel tank and use two wrenches on the fuel lines so you don't make metal spaghetti or pretzels out of them.
Old Apr 16, 2004 | 06:24 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
What if the filter has 150K on it and the fittings are fully corroded?
I have a feeling that I might break the lines themselves in the process. Anyone experience this?
Old Apr 16, 2004 | 06:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is one of the reasons you use two wrenches and put a wrench on the filter and a wrench on the line fitting and spray wd40 all over it and let it soak for a few. If the lines are as corroded as you say they are, you probably need to change them anyway.
Old Apr 16, 2004 | 07:10 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
thanks Trixster. But replaceing those lines seems way involved, messy, and dangerous, sort of like women. jk
Old Apr 16, 2004 | 07:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Only if you are laying on the ground and just the front of the car is in the air. It is almost as bad as trying all the positions of the Kama Sutra manual. Not to mention the fact that the ground I was laying on was a gravel driveway with an unbeknown fire ant bed.
Old Apr 16, 2004 | 11:12 PM
Car: 92 Camaro
I was trying to do this with just the rear end jacked up sky high. I don't know why I didn't think of putting a wrench on the filter to stop it from trying to twist the lines and the filter mount. I'm also not worried about a blast to the face, been working in our drag shop forever. Try being in an enclosed dyno with an alcohol car wearing no eye/nose/mouth protection with no lines connected to the exhaust and an exhaust fan running that barely turns faster than the second hand on a clock. That my friends, will wake sure as hell wake you up.
Old Apr 17, 2004 | 04:45 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
Get proper protection bro. All the fluids and gases in and that come out of our cars are highly toxic, especially if exposed on a regular basis at high levels. Cancer isn't fun and chances are if you expose yourself for long enough it will kill you, or at least make your life miserable.
Now I'm off to attempt getting to my filter out. No whammys please!!!
edit: The nuts will not budge, tried everything short of rounding the nut. Is it now a non serviceable unit due to years of corrosion? With 150k miles of fuel going through it must be clogged right? What to do now?
Old Apr 18, 2004 | 07:18 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
well luckily gas is one of the best things to loosen rusted nuts/bolts, etc. try getting some on the threads and make sure you are turning them in the right direction. i did mine a few weeks back, and even after i pulled the fuse and ran the car until it died, i ended up bathing in gas. it was only dripping , and unfortunately i knocked over my catch can. the gas stripped most of the thick dry skin off my hands and elbows for a little while, and the skin on my arms and back were red and slightly burning(dont soak in it too long)now they are back to their normal sand-paper quality
Old Apr 18, 2004 | 11:38 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Pull the Fuel pump fuses in the fuse box.
Start car.
Wait for it to stall out.
Disconnect old filter...
Reverse procedure
Old Apr 19, 2004 | 07:11 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On some cars, there is no fuel pump fuse inside the car. It maybe be marked FP/*, but if you look at the wiring schematic you will find the fuel pump is not in the circuit.
Old Apr 19, 2004 | 03:09 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I relieved my pressure, so i didn't get sprayed... but I also had the dribble of gas coming out... ended up soaked to the sholders in gas... my arms started burning also. After I was gone, I took a shower, When I got out I looked in the mirror and it looked like I had bad sunburn on both my arms, and they still were burning. I found myself wondering how long the burning would last. It was pretty much over by that evening. It wasn't a very fun job, but atleast the lines wern't rusted in my case.
Old Apr 19, 2004 | 10:24 PM
Transmission: 4l60e
Its real easy for me to get the pressure out of my line now.
Since I switched from TBI to carb my pump is wired in with a fuse now. So I just pull it and walla it'll run out of gas.
Old Apr 20, 2004 | 05:54 PM
Car: 92 Camaro
I'll probably pull it in over the pit at work tomorrow to give it another try.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
