Oil on spark plug
Old Apr 21, 2004 | 02:33 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Oil on spark plug
Hi i have oil on one of the sparkplugs and at full throttle you can see some blue smoke.
What could be wrong?
Could it just be a bad valve seal or worse the piston rings?
The odometer says 60000 miles so its not that much.
The engine doesnt seem to consume any or very little oil if you look at the oil stick.
Old Apr 22, 2004 | 01:02 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
If the valve seal is bad, can i change it whitout removing the heads ??
Old Apr 22, 2004 | 01:05 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
you have to remove the heads
Old Apr 22, 2004 | 01:08 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Hmm anyone knows how to find out if its just a bad valve seal or the piston rings ?
Old Apr 22, 2004 | 01:14 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
nope, you can change valve seals with the heads still attached, just get an airhold adapter and screw it into the spark plug hole fill chamber with air and your set.
Old Apr 22, 2004 | 02:10 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ahh you make it sound so easy, well i hope its not the piston rings. Have to look more before i decide what to do.
Old Apr 23, 2004 | 11:33 AM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
I have always put small diameter nylon rope into the cylinder, then turned the engine over by hand until the rope is compressed upon the valves. This way, the valve CANNOT drop under any circumstances.
Old Apr 23, 2004 | 11:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Ive done the method lonestar states. It works fine. Its just time consuming. But it works all the same. Then just go in with a stud-mounted valve spring compressor. Compress the springs/retainers. Get a magnet to collect the locks. Pop the springs off and have at the seals.
Old Apr 23, 2004 | 12:00 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
If its blowing blue smoke at WOT, and oil on the plugs, its possibly the rings. Seals are a possibility though. Does it smoke at startup?? Or just at WOT?
Old Apr 23, 2004 | 01:05 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
No smoke during startup only at full throttle.
Old Apr 23, 2004 | 01:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If thats the case, chances are good the its the rings. If the seals were bad, you would have startup smoke.
Old Apr 24, 2004 | 12:01 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I had that problem once and tore the engine down only to find the ring gaps were aligned. Every time I put a new plug in that cyl. it would only last about 50 or 75 mi. before it fouled out.
I repositioned the gaps and re-assembled it and wala! it worked! My uncle (a pro mech) said I could have tried squirting a few shots of diesel or rislone in the cyl., removed the coil wire and cranked it over for a bit and It would have caused the rings to move on the piston. I would take a compression test on the cyl. thats giving you problems and the one or two next to it and compare them. That will tell you if you have broken or aligned rings, or a bad valve seal. Ring problem will show lower pressure,
valve seal won't.
Old Apr 24, 2004 | 12:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Correct. Bad seals usualy only smoke on startup and then when they well a bit they stop. It sounds like your problem is much worse. The oil that does leak in from leaky seals will not be detectable on the plugs. Mileage should not be taken into consideration but instead age, as far as valve seals go. Mine are shot and my car has only 34k on her.
Old Apr 24, 2004 | 01:40 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok, she used to smoke on startup but then i fixed my egr problem and she stopped smoki.ng , instead i got blue smoke at full throttle. The idle is smooth and perfect so theres not any real signs of serious engine damage.
Old Apr 25, 2004 | 01:21 PM
Vader's Avatar
Ive done the method lonestar states...
Was that supposed to be some sort of Texas pun?
Old Apr 27, 2004 | 12:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Nope, it was unintended. Didnt even notice it was worded like that.
Old Apr 27, 2004 | 06:49 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
lol
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
