Any other carb guys have this problem?
Old Apr 23, 2004 | 12:12 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok....I think this is sorta normal but I don't know for sure.
Ok If I am driving down a road pretty fast and have to suddenly go hard on the brakes it will sometimes stall out of try to. I'm assuming this is normal because the fuel is being moved to the front of the fuel bowl away from the jets? Would jet extentions help?
Old Apr 23, 2004 | 12:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Dont follow so closely.
Sorry, had to. What kind of carb is this?
Old Apr 23, 2004 | 12:31 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Any other carb guys have this problem?
Could be going rich when the throttle slams shut, causing the motor to quit.
Old Apr 24, 2004 | 01:23 AM
Transmission: 4l60e
I'm not following to close...just if I need to suddenly stop for whatever reason.
It is a 670cfm holley street avenger. Its in good tune and not running rich...It has always done this since I bought it.
Old Apr 24, 2004 | 01:34 AM
AM Racer's Avatar
Did you confirm the float level ( on a level surface) after you installed the carb?
It may be part of the problem.
Old Apr 24, 2004 | 10:30 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It could be the vacuum line going to the brake booster is split and leaky slightly, or even the diaphram in the booster.
Old Apr 25, 2004 | 06:15 AM
Transmission: 4l60e
I hope the booster isn't leaking. That would suck. I do hear a loud swoosh sound when I apply the brakes. I don't know if that is because of the booster or if its normal. I will check the vacuum line today and make sure its ok.
Old Apr 25, 2004 | 09:52 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Normal, unless you can take it out of gear (N) and it still stalls under heavy braking.
Old Apr 25, 2004 | 09:04 PM
Transmission: 4l60e
In N its fine. I kinda figured it was normal.
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
