What is this gizmo?
Old Apr 23, 2004 | 11:16 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What is this gizmo?
What is that thing that i have circled? The car was originally a 305 Crossfire. It is now a Carb'd 355 with the ECM eliminated. I am in the process of cleaning the engine bay up and was wondering if this thing has any importance. The car has no forms of emissions, other than the charcoal canister.
Old Apr 23, 2004 | 11:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cruise control governor.
Old Apr 23, 2004 | 11:21 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Thanks. Dont have cruise. One more thing out from under the hood.
Old Apr 23, 2004 | 11:25 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the speedo cable goes from the trans, to that cruise box, then a 2nd cable goes from the box to the speedo.
you'll need to get the cable ment for a non cruise control car when you take that out.
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well the only problem you may run in to is needing a new longer spedo cable. Most of them the spedo cable runs through that box. 1 from trans to the box, then from the box to the spedo.
Old Apr 23, 2004 | 11:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Well, currently the speedo isnt in the car, either. Is there anyway to make it less "cluttered?" Like cleaning up some of the hoses and wires?
Or, what cars were non-cruised controlled? I take it was a f-bod option?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
So something like that?
Old Apr 23, 2004 | 03:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I haven't seen many 3rd gens with cruise. You may be able to find someone on this board willing to swap. If your parts work. Cruise is nice. But easiest way would be just go junk yard hunting.
Not sure how the cruise **** or lever is but that may be a neat little trick button to keep. Use the cruise switch for NOS or something.
Old Apr 23, 2004 | 07:15 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Not that it matters much, but NAPA sells a piece to connect the two cables together.
Old Apr 23, 2004 | 07:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You know the name for it or have a part number? Never seen one.
Old Apr 23, 2004 | 07:21 PM
87tpi7749's Avatar
Engine: 5.7L
I can check at work Monday, it is in their PSA (Parts Supplies Accessories) catalog.
P.S. I don't work for NAPA, I just remember seeing it in their catalog.
Old Apr 24, 2004 | 09:53 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If you could get a P/N that would be appreciated.
And using the cruise switch for nitrous......Hmmmmi have a NX kit.....
Old Apr 26, 2004 | 05:46 AM
87tpi7749's Avatar
Engine: 5.7L
Part # from NAPA 715-1314. One end is 7/8" x 18 & other end is 5/8" x 18, internal square is .107" it is to eliminate cruise transducer. This should do it.
Old Apr 26, 2004 | 05:47 AM
87tpi7749's Avatar
Engine: 5.7L
I forgot I could edit. Don't mind me.
Old Apr 26, 2004 | 10:16 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Thanks man.
Pistol Pete
Exterior Parts Wanted
Jun 23, 2013 12:55 AM
Hero13
Sep 5, 2011 12:25 PM
bkdamkr
Carburetors
Mar 5, 2011 11:08 AM
eddie jr
Apr 16, 2003 10:33 PM
fazool
Aug 16, 2002 04:37 AM
