MAKING a boost referenced AFPR?
Old Mar 11, 2001 | 05:12 PM
Jester's Avatar
I saw one guy that made his mechanical fuel pump boost referenced.It was pre regulated to 6psi, and had a reference hole to atmospheric pressure. What he did was tap that hole for a vacuum fitting, connected it to the air intake. He gained 1 psi of fuel pressure for every pound of boost.
I'm wondering if I can do something similar with one of the 3 cheap Holley Regulators I have lying around. I've noted they all have a reference hole..like the mechanical pump..but I have no idea if it will work the same.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Mar 11, 2001 | 07:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Should do the same thing... the only issue would be, if the diaphragm "bottomed" out at some point and would go no further. Seems like you could check for that pretty easy though with a regulated source of compressed air.
ICON Motorsports
Old Mar 12, 2001 | 10:28 AM
Jester's Avatar
Thanks RB..I'l check that out.
JSP Motorsports
ICON Motorsports
Old Mar 12, 2001 | 12:14 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The FPR's on the LB9/L98 engines are vacuum and boost regulated. It's a pound for pound relationship - i.e. 10 psi boost gives you another 10 psi fuel pressure. All the injectors care is the difference in pressure from the rail to the intake. WOT@0psi = 50 psi, WOT@10 psi = 60 psi. HTH!
Andris, with 30lb injectors at 50 psi idle, 65 psi WOT
Frozer!!!
Jan 19, 2024 04:55 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
1992Vortec
Aug 31, 2015 08:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
