383 buildup good dynoed combos?
Old Apr 23, 2004 | 03:25 PM
FirstGen's Avatar
Car: 1968 C10, 1984 Z28
Hey guys I am going to do a 383 build up with a 87 and latter roller block probably with 2.02 Vortec heads or something similar. As popular of a motor as the 383 is now I just wanted to hear some of your combos that you are running or have run and had it dynoed to back it up.
I'd like to know specs like CR, cam specs, heads, valve sizes/runners/CC, and all the other usuals. Preferably with dyno numbers to back not computer simulated programs. Track times with a third gen would be even better!
Even if only a couple of you have done this it would be very valuable to me.
Thanks in advance,
Taylor
Old Apr 25, 2004 | 10:38 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
My 383 combo is very streetable with 12in of vacuum at idle and a faily smooth idle. I've ran a 12.02 @ 113 1/4 mile with it. I think the combo has much more potential with a more radical cam and some port work on the heads. Heres the basic combo, you can look on my website for more details.
10.2:1 compression 383, 73 350 block
Dart Pro 1 215cc intake runners 2.05, 1.60 valves
Bullit Hydraulic roller cam .525 lift, 225 intake 230 exhaust duration @.05
RPM Airgap intake
Holly 750DP
Hedman 1 5/8 full length headers
You should be able to get very similar or maybe better results using some worked over Vortec heads.
Old Apr 25, 2004 | 01:10 PM
FirstGen's Avatar
Awesome! Great info thank you very much! Nice trap speed too.
Old Apr 25, 2004 | 01:48 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I thought you'd find this interesting.... If you haven't already seen it.
https://www.thirdgen.org/techbb2/sho...threadid=84340
Old Apr 25, 2004 | 02:33 PM
FirstGen's Avatar
great post! soo much debate about intakes - I think I will stick with my carb
Old Apr 25, 2004 | 03:38 PM
Car: '85 IROC
Engine: LB9
If carb were an option for me, that's what I'd use.
Here in Cal tho you gotta keep your car the way it was originally.
Old Apr 25, 2004 | 03:51 PM
FirstGen's Avatar
yeah it is very strict in texas also... it helps to have buddies that are state inspectors
1984HO
Mar 19, 2021 11:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
