what springs should i run?
Old Mar 12, 2001 | 12:13 PM
GOLD85's Avatar
I have a Comp Solid lifter Cam. its a 282 grind with .495 lift and comp recomends usin ther 981 springs, i plan on using 1.6 rockers and want to know what springs to run.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Old Mar 12, 2001 | 12:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I used to run that exact cam and those exact rockers... I used 986 springs.
981s will not work because of the higher lift created by the 1.6 rockers. Unfortunately the 986s are 1.45" outer diameter whereas the 981s are stock 1.25" outer, so you'll have to get your heads machined if they are stock. It is quite cheap if they're already in the shop though. Many of the aftermarket heads come with that size spring pockets already.
ICON Motorsports
Old Mar 12, 2001 | 12:33 PM
GOLD85's Avatar
What aboot the retaners
R.I.P #3
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
