Help me before I order some pro lightning heads!!!please
Old Apr 25, 2004 | 06:51 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
I am gonna order some pro lightning 200cc cast iron heads with a comp cam 274* extreme energy cam flat tappet and some comp cams magnum 1.6r roller tip rockers...ok here are my questions....Where can I find the complete heads for the cheapest? Do I need longer or shorter pushrods with these heads? Guys I need help really fast
Old Apr 26, 2004 | 04:24 AM
Car: 89 camaro RS
is there anyone to help me?
Old Apr 26, 2004 | 05:23 AM
ede's Avatar
ede
you need to dummy up the engine and check push rod length to know what you need. you can't predict and you can't guess at it. i'd buy the heads bare and assemble them myself with the parts i wanted. the springs that come with them will be cheap and most likely not match your cam.
Old Apr 26, 2004 | 06:21 AM
Car: 89 camaro RS
what do I need to complete bare heads....I know I can buy a cam kit which includes the springs, retainers, locks, and valve seals and then i know i need the valves but then what else do i need.???
Old Apr 26, 2004 | 07:24 AM
ede's Avatar
ede
studs,valves, seals, reatiners, keepers, spring cups, shims, guide plates, springs i think that covers everything you may need
Old Apr 26, 2004 | 07:35 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
See, I disagree, if you're not sure what you're doing I'd order the complete heads, as long as you talk to them and check the spring specs first, and then you can be reasonable sure they're set up right. Now if you're pretty knowledgeable and able to check the spring heights and all that, then i'd buy 'em bare.
If you want to buy them bare, just buy a complete cam kit, it'll come with everything you need except studs and valves and shims. If you go that route spend I'd spend the money and get the Manley pro-flow valves or similar, in my flow bench tests they really do make a difference at lower valve lifts.
Old Apr 26, 2004 | 07:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
THe Pro heads require +.100 pushrods, but i'd measure to make sure.
Old Apr 29, 2004 | 01:31 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
It's a much work to set up a set of heads PROPERLY as it is to build the shortblock. Maybe MORE.
If you don't have all that expertise, buy them complete after a consultation with them concerning the specifics of YOUR engine, camshaft, etc.
Old May 7, 2004 | 03:41 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
Well I would buy the heads fully assembled with the Kit-2 springs and go with Comp Cams Hi-Tech pushrods pt no. 7993-16. They are +.100 over stock and unless your blocks deck height has been drastically altered (which i doubt) they should work fine. Thats the set-up I used on my Protoplines along with a set of 1.6 Scorpion aluminum roller rockers and the valvetrain geometry is right on. As for places to buy them Summit Racing Euipment has about the best price on these heads but Ive seen them on ebay from time to time cheaper.
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
