Replace pistons? Worth it or a Waste?
Old Apr 25, 2004 | 10:10 PM
Project Z's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 Bolt, 3.23 Posi
Need a judgment call...
I've got the 305 apart in the garage (been that way for like a year) and I'm looking to put it back together soon. If it matters, it's out of an '87 Iroc carb.
The question is, will I see any noticable gains from replacing the pistons with some aftermarket slugs. The originals are in pretty good shape. They have 4 valve reliefs and the tops are just slightly dished (not a true flat-top) but I believe that the CR was around 9:1 or even 9.5:1. I've had the heads surfaced witch might raise the CR a little bit and I'm thinking of having the block decked as well.
This question is of course useless if I decide to punch out the holes 0.030 over.
Also, what CR are you guy's running in your 305's? and what did you do to achieve this. I'm shooting for 10:1 to try to build a bit more power.
Old Apr 25, 2004 | 10:40 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
I don't think a half a point of compression is worth justifying the cost of new pistons.
but its not my money, nor my car
Old Apr 25, 2004 | 11:33 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
An overbore, flattop pistons, block decking and head milling might raise your CR 1 point.
Tightening up the quench clearance makes a difference too.
If you do some other mods while you're in there, you'll find a noticable gain.
http://kb-silvolite.com/calc.php?action=comp
You can figure it out more closely with this calculator.
Old Apr 26, 2004 | 02:06 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
yeah..and those are good pistons to go with if you are thinking about it. Those Keith Black series
Old Apr 26, 2004 | 05:25 AM
ede's Avatar
ede
i wouldn't replace pistons unless you were boring the block oversize.
Old Apr 26, 2004 | 08:07 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i'd have to agree with ede.. and I wouldn't bore the block oversize unless it actually needed it. A lot of people do it for some unknown reason, but it makes about as much sense as pissing in the wind..
Old Apr 26, 2004 | 12:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not understanding the part about spending money on a 305 shortblock. I've done the math many times, it never comes up favoring the 305 vs. getting a 350 builder.
It's not like I'm a 305 hater, either. Or against making one make more power. I drive one to work every day. But, the economics of $'s/HP just don't work out once you start spending money on the 305 shortblock.
Old Apr 26, 2004 | 01:35 PM
Car: '85 IROC
Engine: LB9
I'm not trying to be disagreeable. But as far as getting new pistons for a std bore block, it's not as if it can't be done. It's more a question of how much of a perfectionist you want to be, how worn out the original bore is, and how much $$ you really want to invest in your 305.
It might not make a lot of sense to some guys to do it, but then to some guys it doesn't make sense to rebuild a 305 at all.
Personally if I were building a 305, I'd do it as inexpensively as possible, and put any real money into parts that could be swapped to a 350 at a later time.
Considering that your engine is torn down already, and you're going to be investing in parts to reassemble it, a set of cast flattops might not add more than $120 to your total incl labor to press the pins in.
My main reason for telling you this is cause IMO the factory dished pistons are a "power disabling" piece of equipment, and to me it makes less sense to put together an engine with those things in there than to replace them with a set of std bore flattops.
I have done it, successfully
No flame intended... Just my opinion
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
