Where to get engine to trans bolts
Old Apr 26, 2004 | 10:33 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Took the trans off the car recently (700r4) and the engine to trans belhousing bolts turned out to be an improvized mix and match of bolts from ace hardware (scary).
I looked at summit and arp's website but I cant seem to find these listed anywhere. Am I just stupid and dont know what they are called or what. Where can I get a good set?
Old Apr 26, 2004 | 11:03 AM
GlenYappa's Avatar
(Stretching for first auto catalog within arms reach of computer chair)
Jeg's catalog - ARP bellhousing studs - 2 kinds
Pro series - 070-245-0901
Stainless - 070-445-0901
Glen
Old Apr 26, 2004 | 11:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
At summit, replace the "070" with "ARP"
Old Apr 26, 2004 | 11:41 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The factory uses 3/8"-16x1-1/2" grade 5 bolts, nothing fancy. I used grade 8 in mine.
Old Apr 26, 2004 | 12:00 PM
ede's Avatar
ede
yeah factory is a regular hardwear bolt, grade 5s. i use grade 8s.
Old Apr 26, 2004 | 12:15 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ahh ok -- I saw those studs but wasnt sure if there might be a bolt replacement. Thanks for the slap on the back of the head.
Old Apr 26, 2004 | 01:02 PM
Ricktpi's Avatar
After all the trans housing is cast aluminum. What's more likely to break cast aluminum or a steel bolt?
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
