blue smoke
Old Apr 26, 2004 | 01:50 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
blue smoke
Hi ihave a dumb question since i dont now that much about cars .
The car used to send some blue smoke at start-up but since i fixed the egr so its working properly the smoke never came back. At full throttle it sends some blue smoke, can something else but valve seals, piston rings cause this ?? The engine work great, smooth idle and good power so i dont know what could cause this blue smoke.
Old Apr 26, 2004 | 04:16 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Besides those two....the only other thing I could think of is a problem with the PCV return line. In other words, liquid oil somehow getting into the vac line INSTEAD of oil vapor.
Old Apr 26, 2004 | 11:37 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok, so where is this pcv return line located ? I have never changed the pcv valve , should i do that?
Old Apr 26, 2004 | 11:44 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
PCV is located on the LH valve cover hose is between PCV valve and intake base.
/N.
Old Apr 27, 2004 | 07:25 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Its very possible that i have a problem with the pcv thing, it smells oil in the car at full throttle.
Old Apr 27, 2004 | 12:30 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok i found the pcv, the right one was just a hole and it had a lot of oil and was really messy and the left one looks just fine. Look at the pictures.
Could this bee the cause of all my troubles with the blue smoke and the smell of oil inside the car when i hit the throttle?
Old Apr 27, 2004 | 12:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Well, considering as how a PCV only costs like $3 MAX at most automotive stores, it doesnt hurt to replace it. Also, blue smoke at WOT can also be blamed on rings that are shot or have been aligned.
Old Apr 27, 2004 | 02:17 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok, should the pcv on the passenger side just be a hole or am i missing something. The left one doesnt look like that.
Old Apr 27, 2004 | 11:36 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
It looks right, the valve is only placed on LH side valve cover.
/N
Old Jun 17, 2012 | 09:11 PM
Mac10's Avatar
Re: blue smoke
I push a big cloud of blue smoke under full throttle now . but not at start up or part throttle . I like to listen to that FUEL song by Metallica and floor it to strategically place a blue cloud of smoke into a bus stop . These people need to know my pimp game is strong , and that I keeps it real !
http://www.youtube.com/watch?v=Wdqo9aO0fyo
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
