Air Conditioning recharge problem
Old Apr 27, 2004 | 10:26 PM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
Well im tryign to recharge the ac on my 92 camaro rs. it has an l03 in it just to make that clear. well im trying to convert it over to 134a. the system was completely empty before i started this so i changed the o rings and drained the oil. now i hooked everythign up. fire the engine up and click the ac to max and blower on full. open the valve and wait to see if it will fill up enough to allow the comprssor to kick on. wait 10 minutes nothing happens. so i start to try and find the ac pressure switch cause i was told that if u jump the wires it will force the compressor on. i tried the sensor on the metal tank thingy by the blower(not sure what its called) and the sensor down near the exhaust manifold. both just blew my ac fuse so im kinda lost as to what to do. can anyone help me?
Old Apr 27, 2004 | 11:13 PM
AM Racer's Avatar
Look for a short,maybe a pinched or melted wire at the compressor. The switch on the tank is the low pressure cutoff so that would have been the correct one jumped to complete the circuit.
Old Apr 28, 2004 | 12:47 AM
ronterry's Avatar
Car: '94 Corvette
I agree with 'AM Racer', but for grins did you have a vacuum pulled on the system? You don't want any air in the system prior to charging.
Ron
Old Apr 28, 2004 | 02:44 PM
collin's Avatar
The first thing I would do is check the resistance on the compressor clutch coil. It sounds like it is shorted and is blowing the fuse when you try to kick on the compressor.
Old May 11, 2004 | 10:46 AM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
hmmm i measured the resistance today.... 4.4 ohms. that seems a little low to me. can anyone tell me what it should be?
Old May 11, 2004 | 10:49 AM
collin's Avatar
I'd have to check mine but that does sound low. What happens if you apply 12V directly to it with some jumper wires? It should engage whether the engine is running or not...
Old May 11, 2004 | 10:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's about right. Maybe a little higher than usual, if anything.
I don't know what you jumped; but what you need to do, is disconnect the connector from the low pressure cutoff switch on the accumulator, and connect the 2 terminals of the connector together with an insulated wire. DON'T connect anything to ground. That should allow the compressor to come on.
Trace the wires and make sure there's not some kind of wrong connection or something somewhere. The dark green wire should go straight from the cutoff switch connector to the clutch.
Old May 12, 2004 | 03:02 PM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
wait the cutoff switch is the one on the back of the ac compressor? i never tried jumping that. i didnt think it would be there. oops
Old May 12, 2004 | 10:50 PM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
is that the low pressure switch??? i never got a chance to try it, but i really owuld like to know first
Old May 14, 2004 | 06:30 PM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
can some one please tell me if thats the right thing. i ran out of 25 amp fuses and dont feel like blowing the ones im using.
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
jackhammer
Aug 15, 2015 10:04 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
