Engine paint
Old Mar 13, 2001 | 10:50 PM
93ND500's Avatar
Engine paint
Who makes a GOOD engine paint.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Mar 13, 2001 | 11:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I use Mercury Marine paint. My preference is the charcoal color. Their primer is good too.
ICON Motorsports
Old Mar 14, 2001 | 01:06 AM
rhawki's Avatar
POR, VHT, Plasti-Cote, Duplicolor - probably in that order of preference. Some recommend an epoxy primer and a clear coat.
I've used POR-15 on some body parts, and that stuff is ungodly tough... Wear gloves! They sell engine paint kits which comes with stripper/cleaner and common color choices. $40
-Rich
Old Mar 14, 2001 | 06:04 AM
merf23's Avatar
I use a zinc phosphate/chromate primer (available at marine stores) and a single stage urethane (available at auto paint supply stores). I flows so nicely that you can brush it on if necessary. Its resistant to gas and brake fluid. I have even used it on brake calipers with excellent results.
BTW, my engine is Dodge Viper Red.
1984 Z28 (L69) monochrome tangerine orange with IROC decals and hood
1987 IROC wheels with Goodyear GSC's
305 from 87 IROC with 1994 LT1 cam (203/208 .450/.460")
performer intake with holley 600 (#1850)
Qjet is in the works
dynomax cat-back
non WC T-5 with 0.73 5th
3.27 nine-bolt
Old Mar 14, 2001 | 01:55 PM
greearhr's Avatar
The Zinc chromate is available in black now from auto paint stores. It's recomended as a good frame paint with no overcoat so if you want black you might be able to use it alone.
Comes out kind of satin.
Bear Tracks
Old Mar 14, 2001 | 06:15 PM
ede's Avatar
ede
i use rustolium
ICON Motorsports
1st & 3rd
Old Mar 14, 2001 | 07:48 PM
93ND500's Avatar
Hey ede. Which type of Rusto? Is it there "Hard Hat" series or just their plain enamels?
Old Mar 14, 2001 | 07:52 PM
Vader's Avatar
Plain Rust-O-Leum enamel. The "Hard-Hat" industrial enamel is very thin, and doesn't cover as well IMO. Regardles of what paint you use, some of is is alwatys going to char around the exhaust ports unless you never run the engine.
Allis Chalmers oragne is an exact match for the "original" Chevrolet SBC color.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 14, 2001 | 11:11 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Go with the POR paint....you have a wide choice of colors and it's hard as nails.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
