broke off spark plug in head...HELP!
Old Apr 30, 2004 | 02:18 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
OK guys I could really use some suggestions. I'm in the middle of a major tune up right now. My uncle gave me his 88 camaro TBI 305. I dont think he did a tune up on it in years...so I got a new cap and rotor, 8.8 mm accel plug wires, bosch platinum plugs, and some cheap dynomaxx headers. I got both stock manifolds off yesterday, only took 3 hours and I only had to remove the air pump hoses. I changed the drivers side plugs and put the headers on...then I was taking off the last spark plug on the passenger side and SNAP! I felt a knot building up in my stomach...the rusted old plug snapped between the nut and the threads, so the nut part was in the socket, but the threads and half of the ceramic are still in the head! please tell me that theres something I can do to remove the rest of it without having to take off the head, this has to have happened to some of you before
Old Apr 30, 2004 | 02:41 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
That sucks. I had that happen once, and I had to pull the head to get it out. I don't think there is any safe way to do it without pulling the head. Once I pulled the head, I got a punch and punched the ceramic and the electrode through the plug threads, and then used an easy out on the rest of the plug. Becarefull not to damage the threads in the head though. That is a problem you do not want to have to deal with. Sorry to be the bearer of bad news. but if you find a way to do it without taking the head off, let me know how you did it.
Old Apr 30, 2004 | 02:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
depending on how its broken you may be able to use a reverse drill bit or an easy out, might help to spray it with some rust penetrant first
Old Apr 30, 2004 | 02:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The square type of screw extractor usually works on those. Better than the left-hand-spiral type.
Old Apr 30, 2004 | 03:01 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Any decent hardware store should sell screw extractor sets. For less than 20 bucks id give this a shot before taking off the heads.
Old Apr 30, 2004 | 03:44 PM
ya I have a set of those...too bad its the one on the passenger side against the firewall...
Old Apr 30, 2004 | 05:43 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Put in a 350, problem solved
Old Apr 30, 2004 | 05:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless the porcelain came clean out with the nut, I don't see any choice but the pull the head.
And I've never seen nor heard of this happening.
Old Apr 30, 2004 | 05:54 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
I've never heard of this happening before either, ever. Definitely try using a reverse drill bit if you can get to it like someone else said earlier.
Old Apr 30, 2004 | 06:00 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
If the threads are the only thing left it may not be that hard to get out. I'd try to get at it with a small punch and see if it would turn. But, like already mentioned, don't screw up the threads in the head!
Old Apr 30, 2004 | 07:21 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
is there any metal left sticking out of the head? if there is something that you can grab onto, try using a set of vice grips.
Old Apr 30, 2004 | 08:39 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i hate to say it man if it was rusted enough to break off your probably gonna have to take the head off the engine and go from there i know its a pain in the **** ..but sometimes you have to do what you have to do ...
Old May 1, 2004 | 10:23 AM
Vader's Avatar
Never seen nor heard of that? It happens, expecially with standard AC/Delco plugs, Motorcraft, and Autolites. the lack of any plating and subsequent corrosion protection for the plug shell allows a lot of corrosion:
That's why I use Champions - That, and several other reasons. That may also be why most AC platinum plugs are plated or use 400-series SS as a shell. At the 100,000 mile projected service interval, plain plugs would never come out intact.
Old May 2, 2004 | 07:58 PM
ya thats what happened with mine, except it broke further down, between the treads and the nut, and the porcelin actually broke in half too along with the center (wire)
Old May 3, 2004 | 12:40 PM
HELP!!?? any more ideas?
Old May 3, 2004 | 12:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What have you tried and such?
Old May 3, 2004 | 03:51 PM
WOOHOO! I used an easy out and it came out!!! thanks guys
:lala:
Old May 3, 2004 | 05:37 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
A nice picture of the culprit would be nice.
Old May 3, 2004 | 06:16 PM
THEGENERAL's Avatar
:lala:
congrats man you got lucky on that one ..ive seen guys have to take em to machine shops to have em fixed...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
