Rev Kit + Lifter Spider Plate = ??
Old Apr 30, 2004 | 06:49 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Will a Rev Kit work along with a Spider Retainer plate? I cant seem to find this info while searching.
Old May 1, 2004 | 08:40 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
AFR makes a set specifically for oem roller cams. When we were trying to install schultzy89gta's afr sent the wrong ones first and they didnt fit. Sent them back and got the right ones, no problems.
Old May 2, 2004 | 11:09 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Chevymad, Which one did Schultzy89gta get? All the Rev kits Ive seen should clear the retainer.
Old May 2, 2004 | 08:42 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Hey well there were a few on ebay, I dont really need one for the cam im going to be running but i figured it would be extra insurance, so what the heck.
they go on ebay for $33~ all the time, $33 is fine with me, but I planned on using the spider plate with my cam, so i wasnt sure if it was even worth trying. I guess there are different kinds so ill just have to buy one and see if it will work or not. I can always modify the spider plate (again) to fit i guess.
Old May 3, 2004 | 04:12 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
whats a spider plate????
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
