What other T-5 can I use in my car?
Would one from a Mustang work? Or a datsun 280zx? I know they all utilize the T5 Borg Warner.
What about other Fbody years. 87? 88? 89?
Will I be able to use my brand new Zoom clutch with it? That is my main concern. I don't want to do another clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March alt. pulley, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your 91 should already have a world class T5, and the only upgrade to that is a Tremec, a Richmond 6-speed, or a T56.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: Death Mobile
Engine: 666 c.i.
T-56 from a wrecked 4th Gen. Or you can keep replacing and replacing and replacing your WC T5.
Your supercharged 305 produces as much (if not more) power than an LS1. You need one of the best out there. Do it right, do it once.
BTW, with all that power, don't be surprised to also be looking at a rear end in the future. A Ford 9" should be in your "future mod" budget.
This is the cost of making power in a 3rd Gen, once you get into the 300-350 HP range, you need to start thinking power train.
Linson
Aug 21, 2015 02:12 PM
