This sucks big vaccum! Mabye.....
Old Mar 15, 2001 | 07:46 PM
MATEOZ28's Avatar
For some reason my car will not idle at anything below 20*. Whenever I unplug the hose from the charcoal canister to my throttle body it works fine. I put the engine together and may have gotten one of the vaccum lines wrong but they look right. Any suggestions what it could be? I have a 1991 Z28 TPI 383.
Old Mar 16, 2001 | 01:45 AM
MATEOZ28's Avatar
Oh, c'mon nobody knows about this stuff?
Old Mar 16, 2001 | 09:16 AM
jobryan26's Avatar
Did you refer to the Emissions sticker under the front of your hood to make sure your vaccum lines are correct?
'87 Trans Am
305 TPI:
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Old Mar 16, 2001 | 11:02 AM
MATEOZ28's Avatar
I have an SS hood man I wish I would have thought about keeping the routing sticker though. It's weird though, everything seems to be routed correctly but the only problem is when I plug in the top line from the charcoal box. Could it be bad?
Old Mar 16, 2001 | 12:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Huh, what is your problem exactly? There is no such thing as making too much vacuum at idle, in fact in the old days that was one of the preferred method of setting your idle mixture/timing was to set for max vacuum. If your charcoal canister being hooked up is giving you a driveability problem then you either have something hooked up wrong or your canister purge is screwingup or something.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Mar 16, 2001 | 12:24 PM
MATEOZ28's Avatar
Well the problem is it will not idle correctly. When I go to put it in 8* it almost dies on me. When I get a good sounding idle *usually around 24* BTDC* it idles but it bogs down and back up continuesly. Whenever I hook up the ESC wire after setting timing it screws up even more *It cuts out at half throttle while driving*. I can set it at 8* if I adjust the TPS but I dont think thats right because I have a 91 and shouldnt have to adjust the TPS right? Also whenever I disconnect the vaccum from the charcoal canister to the throttle body the car revs up real high and allows me to set the timing to 8* perfectly without idling problems. I've replaced the TPS and virtually EVERY sensor on the car when I did the 383 swap. Please give suggestions this is out of my arena of expertese. I'm the kinda guy who knows alot about these cars but not alot of the basics. THANKS my PeEpS hehehe
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
