urgent need help
Old May 2, 2004 | 03:55 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
urgent need help
well guys big problem im having here we go,welll when i started my engine on today like every 15 sec it makes a knocking noise like something broke in side the engine the noise come from the engine inside and then like every 45 sec the engine misses like crazy and want s to turn off by it recovers then if u give it gas it wont get rpms and if it does it turns off wat the hell can it be bad cranks f**k up motor need help
Old May 2, 2004 | 04:00 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
Check your cap and wires to make sure they're all on and getting a good spark. Are you getting plenty of fuel?
Old May 2, 2004 | 04:02 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
thats all good y?
Old May 2, 2004 | 04:12 PM
Car: 92 Camaro
Because it sounds like your fuel pump is bad.
Old May 2, 2004 | 04:15 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
f/p had right pressure i think my timing chain sprocket or something broke
Old May 2, 2004 | 04:17 PM
Car: 92 Camaro
Does the engine shake or rattle?
Old May 2, 2004 | 07:28 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yes when the knocking starts a lil and then when it wants to shut off alot ,shakes the whole car y?
Old May 2, 2004 | 08:18 PM
Car: 92 Camaro
Well, with that description it sounds like it's out of timing.
Old May 4, 2004 | 04:11 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well i adjusted the timing and the knocking went away but now when my car is on gear it misses likes crazy and then i did a dia test and i got code 33 i belive map sensor can that be it ?
CALIROCZ28
Sep 26, 2004 05:47 PM
CALIROCZ28
Northern California
Feb 29, 2004 07:32 PM
CALIROCZ28
Southern California Area
Feb 27, 2004 12:43 AM
