Strange oil consumption?
Old May 3, 2004 | 08:38 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Transmission: 700R4 auto
I have an 89 Firebird with the TBI 305. After an oil change I can go to about 1000 miles then I have to add a quart. No big deal really...but, after I add the first quart of oil I have to add a quart every 400-500 miles until the next oil change. Anyone else have this problem? Anyone know what might be the cause? I have already tried PCV valve and crankcase breather. Please help, I'm baffled.
Old May 3, 2004 | 08:53 AM
ljnowell's Avatar
well, if you are low on oil, its gotta be goin somewhere. Check radiator, check the ground under the car, and look at the undercarraige. If you cant find any oil there, that only leaves one other leaky spot. You are leaking it out your exhuast pipes. That sucks
Old May 3, 2004 | 09:35 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Yeah, that is something I failed to post. I haven't found any sign of leakage on top or bottom of the motor. There is a slightly damp spot on the front seal of the intake, but I think that is from a bad thermostat housing gasket (need to replace). I'm not getting anything out of the exhaust either, no visable smoke and no liquid.
Old May 3, 2004 | 10:35 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Are you running the smog pump? It could also be leaking in the rear somewhere. Like the oil pan gasket on the back side. Jack up the car and crawl under there.
Old May 3, 2004 | 11:02 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
I'll give that a look when I get the chance. Forgive my dumbness here...but, what exactly is a smog pump? What does it do, and why would oil leak from it?
Old May 3, 2004 | 11:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Often times, if people pull the smog pump, they forget to plug the top hole.
When you pull the smog pump, there are 2 bolts that go into the engine block. the bottom one is ok. However, the top one is what looks directly at the fuel pump pushrod, if so equipped. However, by looking in to the fuel pump pushrod, you are also looking in directly into the crank case.
That is the front of your engine (well, so to speak). The bolt hole i circled is one of the smog pump mounting holes. It is also the hole that you have to plug if the pump is pulled.
Old May 3, 2004 | 01:29 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Of course I haven't had the time to check this out yet...but, wouldn't a hole like the one for the smog pump make one heck of a mess rather than be a mystery leak? I don't know, I have a 1-hour 1-way trip to and from work every day...could be burning off.
Old May 3, 2004 | 01:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Well, first things first. On your engine, is that hole bare or is it plugged? If its plugged, make sure its sealed good (no oily residue around the plug) and if it is sealed good, we're looking in the wrong area.
Old May 3, 2004 | 02:44 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Will check this evening when I get home. I'll let you know then.
Old May 3, 2004 | 05:50 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Do you puff smoke on a cold startup? Does your rear bumper get a coating of black soot on it? Lacking obvious oily spots on the undercarriage, the only other places the oil could go is the coolant or engine. Coolant would be obvious since the oil cannot go anywhere, it will accumulate, making the coolant look like a mess. A puff at cold startup is valve seals. Slight smoke during regular driving means rings. Have someone follow you while you tromp on the gas. Does grey smoke come out? A quick spark plug check can tell if you have oil problems and a compression check would confirm it.
Old May 3, 2004 | 06:38 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Stekman, I checked for the smog pump and I believe it is still intact and not leaky.
I have had the valve guides replaced within the last few months to cure the cold start puff. That is no more. As for romping on it and seeing smoke I can't recall seeing any while driving since I had the guides replaced. Before you would see a little puff on deceleration...but, as far as I know that is gone. And the plugs look good too. I'm starting to suspect the intake gasket more since the front is a bit wet...it's just hard to tell because the thermostat housing has been leaking on and off. How long does a factory intake gasket usually last?
Old May 3, 2004 | 10:24 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
do you have the flywheel inspection cover on still ??? ive seen cars leak from the rear seal of the engine and almost fill the cover up with oil ...but usually you would notice some kind of oil spot on the ground under your car ........also have some one get in your car and gas it pretty good and you stand behind it and watch the pipes and make sure your not haveing blow by from the rings at higher rpms...if your drivin an hour to and from worK you wouldnt notice it smokin out the rear as much if your on the high way ...
Old May 3, 2004 | 11:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
When you say your front of the engine is damp, where do you mean exactly? Where the thermostat housing is mounted and the front china wall gasket is is a big gap. If the moisture is present mainly below the front china wall gasket, i would suspect that as a possibilty. But if its damp above the china wall gasket then yes, it probably could be blamed on the thermostat housing.
Have you done any disassembly/reassembly of your engine?
Old May 4, 2004 | 10:03 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
well, I know the thermostat housing leaks occasionally but it really doesn't go down the front of the intake so much as the side of the front. The gasket on the fron of the intake (kinda has that sealant that kinda hangs out) looks to be wet from the sealant down. But, it doesn't look like it is gushing or anything. But, it definately looks and feels wet...I don't think it is coolant either.
Old May 5, 2004 | 07:43 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
ttt
Old May 5, 2004 | 10:17 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Are you sure it doesnt leave a puddle or anything on the ground?
Old May 5, 2004 | 10:36 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
I do park on gravel primarily. But, eventually it's bound to show up even then. I wish there was a puddle...it would make this much easier to figure out.
Old May 5, 2004 | 11:16 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Take a paper towl, kleenex, anything white, and wipe along the front intake gasket. See if you cant pick up some of the residual leakage.
Old May 5, 2004 | 11:51 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
if you park on gravel just take a piece of cardboard and put it underneath your engine, any oil spots should show up if you have a leak.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
BWilcox
Sep 20, 2015 12:19 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
