Burning oil - and going from synthetic to regular
Hi everyone,
So last Friday I noticed that my car was low on oil by THREE QUARTS!!! I've noticed no leaks, so I dumped in a quart of fluid to help oil stop burning, and added 2 quarts of mobil 1 synthetic (been on synthetic now for 6 months). Today, Five days later, down a full quart again!
Should I go back to regular since it's thicker/burns slower? I drive about 100 miles a day. Is this a sign of the motor going altogether? Please help!!!
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think you are asking the wrong question. Instead of "which oil to use in the engine that is burning oil?" you should be asking: "why is my engine going through so much oil?"
Does it puff bluish smoke at startup? how about open throttle?
Car: Z28
Engine: Sb2.2 406
Then you have a leak somewhere. Oil does not evaporate inside the engine...
Rear oil seal, intake gaskets on the china wall, timing cover, fuel pump (if mechanical) or block off plate gasket, smog pump hole, all things to consider.
Do you have the smoge pump on your car?
Car: Z28
Engine: Sb2.2 406
Oh its a cali car? then never mind on the smog. Your leak is elsewhere. Yes, changing to conventional oil is fine.
Either way, though, you need to find that leak. Does it drip anything anywhere?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Layne
If I did want to go back to regular oil though, would that be ok?
you can pour in half a bottle of syn, and half of the cheapest crud they sell... it all works together without issue. heck, most "synthetics" are blended anyway.. lol (castrol comes to mind..)
in eithercase, you NEED to find where the oil is going. if its not burning (and you would notice one quart of oil burning) you have a leak somewhere..
Transmission: 4L80E/4L80E
Re: Burning oil - and going from synthetic to regular
I dumped in a quart of fluid to help oil stop burning...
...and added 2 quarts of mobil 1 synthetic (been on synthetic now for 6 months).
I haven't found a leak so I'm going to take it in for an oil change and see if they can tell anything. The synthetic I've been changing about every 4k miles till now.....used to burn off a quart in between oil changes, which isn't that much. car has 172 k on it, motor maybe 45k or so.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
My car used to burn a LOT of oil and I never actually saw smoke, 'course my exhaust dumped under the car....that played a big factor.
I would use some thicker oil, maybe some 20-50 unless you're in a really cold climate. That might help slow down the burning a little bit, hopefully. IF you are burning.
45k is NOT a lot of miles for a motor...... Sometimes the simplest solution can be the right one. Like a loose drainplug or improperly tightened filter.
