Tach not working
Car: 89 RS
Engine: 305 TBI 215,000+
Tach not working
Why Does my tach not read correctly? Some times it reads 1500, and other times it reads 4500. I can be at idle and it is at 4500 or doing 80 in 4th gear reading 1500. It will sit at 1500 all day then quickly jump up to 4500, then just drop back down later on. Any Thoughts?
john
john
Car: 89 RS
Has anyone ever had to fix there stock tach before????? I am trying ot keep the interior all original, so i am less likely to get her broken in to.
john
john
Car: 4
Engine: 6
Transmission: 5
They break all the time; but not usually like that. That sounds more like an intermittent connection somewhere.
Have you checked the cluster's ground? Taken a look at the flex circuit board on the back of the cluster?
Car: 89 RS
so you are saying to take off the cluster and clean the circuit board on the back with like isopropyl alcohol and see if that works?
john
john
Car: 89 RS
Originally posted by Red Devil
Do you have any aftermarket spark boxes installed? If not check your connections, if you do you have to get the filter.
john
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by frogmanjohn
Unit????
Unit????
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check this.
In this test, what you are actually testing is the voltage going to the tachometer connector on the instrument connector located on the right side of the dash. If the voltage is correct and the tachometer is reading wrong, you replace the tachometer. See the third picture for the pin number and location. BTW, I forgot to mention the wire for the tachometer is the white wire coming of the gray connector on the ignition coil. Before going to the instrument panel it splits off and goes to the ESC module.
In this test, what you are actually testing is the voltage going to the tachometer connector on the instrument connector located on the right side of the dash. If the voltage is correct and the tachometer is reading wrong, you replace the tachometer. See the third picture for the pin number and location. BTW, I forgot to mention the wire for the tachometer is the white wire coming of the gray connector on the ignition coil. Before going to the instrument panel it splits off and goes to the ESC module. Last edited by Trickster; May 14, 2004 at 12:33 PM.
Car: 89 RS
Originally posted by Trickster
I don't mind, it is the GM service manual for the 1989 camaro's.
Car: 89 RS
cool, thanks bud, now i just have to figure out were in the heck my pm inbox is, especially now that i am athome on my dial up connection. Damn, i almost miss being at work with our T-1 Connection..
john
john
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey John,
Look at the bottom of your post and you will see a button there that says PM. click on that and then click on Private messages in the upper right side of the screen.
Car: 89 RS
Hey John,
Hey John,
eightsixseven
Dec 16, 2024 01:50 PM
