So yesterday I get off work...
Old May 14, 2004 | 06:50 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
.....and Im about a mile from home.Im siiting at a light waiting to make a left.My steering wheel is kinda resting on my leg due to the screws in the tilt column coming loose.Im too lazy to spend 3-4 hrs to fix it and too cheap to pay someone else .Anyway,the light turns green and I make my turn.About 3/4 the way around the corner...POW!!!!! my friggin steering wheel twist at the tilt.I mean the wheels in my crotch and the turn signals on the right and my keys are on the left!!!
The car dies and luckily rolls into a yard.Since I was coming from a stop I wasnt going fast.No-one was hurt and the Camaro was unscathed(other than the steering wheel).I consider myself lucky since usually that lights green and I hit it alot faster.
Moral:dont put it off!!!!If you know its f'd up fix it or it may bite you in the *** someday! It only cost $112 to fix. It couldve cost my life of someone elses.
Old May 14, 2004 | 07:05 PM
MasterEvilAce's Avatar
Nice story...
So the steering column fell? Or the wheel broke off, or the tilting part just came loose and spun around?
Old May 14, 2004 | 08:09 PM
ponykiller's Avatar
Engine: lo3
I guess you can say the tilt came loose,fell off and twisted around.
Old May 14, 2004 | 08:42 PM
onebinky's Avatar
Why would you put off fixing a safety issue like that though? That's like ignoring the huge puddle of brake fluid under the car.
What ended up being the problem with it?
Old May 14, 2004 | 10:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
wow and i thought i was bad about not fixing stuff like a tail light or head light right when it goes out i dont feel quit so stupid now thanks alot for makin me feel so much better ....lol...
moral of this story :::: if your cars steering colomn is broken dont try and drive it any way unless your shoes are broken and you cant walk...LMAO
Old May 15, 2004 | 09:52 PM
ponykiller's Avatar
Engine: lo3
I put it off in part due to being told it wouldnt come off.I know better now.:lala: thats why I posted a warning to the other lazy asses out there
It ended up being the 4 screws coming loose enough to come completely off.Luckily nothing else broke during the incident.
Glad I could help
That reminds me....I got a blinker out I need to fix..... [QUOTE][i]
no doubt
Old May 15, 2004 | 10:02 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Re: So yesterday I get off work...
Yeah, and if you hadn't of waited so long, it would have cost nothing.. Those four torx screws that hold the base tilt assembly come loose quite often on GM tilt columns... So yeah, go fix it now everyone!
Old May 15, 2004 | 11:31 PM
onebinky's Avatar
Well, at least the worst that came out of it was maybe a messed up lawn
:nono: No more putting of safety things Could have been a child or another F-body instead of the lawn.
Old Sep 17, 2004 | 01:48 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
mine is getting loose at the tilt it theyre an easy way to pull it apart? any one have a diagram or anything?
Old Sep 17, 2004 | 03:58 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
pictures and all http://home.t-online.de/home/O_Scholz/steering.html
Old Sep 17, 2004 | 04:14 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
thanks
F-body-fan
May 4, 2026 09:42 AM
FormulaEngland
Sep 30, 2015 01:50 PM
thekurlyone
Sep 30, 2015 12:54 PM
R13_Braz
Sep 18, 2015 05:00 PM
Out-Cast
Sep 11, 2015 08:03 AM
