Iridium Spark Plugs, check it out
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
If anyone is looking into buying these very expensive spark plugs go directly to their site:
http://www.denso.co.jp/PLUG/iridium-e/index.html
These spark plugs sell for about $13.00 each, $68.00 for a set of four, and $99.00 for a set of six.
Now, is the power gain worth the money. I guess if you have the money then it's OK.
Car: 04 GTO
Transmission: M12 T56
My spark plugs work just fine. If your current spark plugs work OK, why bother spending 13x as much on them. Just like w/ ignition boxes, this will only help if you are running seriously out of tune and misfiring due to the off mixture.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
Well I'mm gonna disagree with ED on this one,
I drive karts and use the new Rotax-max engines. These Denso Iridium power plugs come with the motor from the factory and are the only plugs that work well and let's you rev-it up to 14,000 rpm's. even in brand new motors those other plugs can't cut it. NGK and Bosch make a plug that's compatible but those are almost as expensive...
So they are not for out of tune engines but also for the utmost extreme engine needing the very best...
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
My LS1 has Denso's from factory. They seem like an okay plug but i don't know what the big deal is honestly...unless it's a Sam's Choice Spark plug shouldn't it work the same?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
Car: '87 Camaro LT
Engine: 355 L98
i use pure iridium at work, it is by far the softest metal i've ever worked with, other than liquid mercurey. how is it or how does it's "hardness" enhance the electrode of the plug? is it an iridium alloy? just about have to be i'd guess to add hardness to the electrode.
Car: '87 Camaro LT
Engine: 355 L98
evilstuie
Feb 28, 2016 03:33 PM
