smokes but what is it
Old May 16, 2004 | 09:18 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
white smoke when i hit the gas, its not oil. but i cant tell if its rich or lean or maybee not enough octane rating?(91) only when i hit the gas it smokes below is my setup.
Old May 16, 2004 | 09:27 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
white smoke is usually water....head gasket maybe.
Old May 16, 2004 | 09:40 PM
radiateu2's Avatar
or intake gasket, cracked head, cracked block....suggest doing a compression test and see if there is a difference between cylinders....could also be condensation in the exhaust boiling off but if it smokes after warmup.....you gotta problem
Old May 16, 2004 | 10:51 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
maybee water in the gas?? it doesnt seems to smoke realy bad just puffs when i rev it up or hammer on it accelerating. has not ran hot or ran different either. it sat for a while could condensation be a problim? i just filled it up with the 91. before it was stored 8 months it had a 50/50 mix of cam2 race fuel and 94 there was a 1/8th tank left in it.now im almost though my first tank of 91. when my last car had a bad intake it forced air into the block and made it run hot and boil over... this runs fine.
Old May 16, 2004 | 11:00 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
try pullin the spark plugs and inspecting them that will give you a good idea of whats goin on
Old May 17, 2004 | 12:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do a compression test on all 8 cylinders. White smoke is generally associated with coolant getting into the combustion chamber some how. The most common way is either via head gasket or intake gasket.
Also, like stated, yank the spark plugs one by one and inspect the end.
Old May 17, 2004 | 09:25 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok ...what are the plugs gonna look like if its because of water?
Old May 17, 2004 | 09:50 PM
radiateu2's Avatar
If it is water in the cylinder that plug should be virtually steamed perfectly clean....thats not always the case though....compression test is a much better indicator....water is the fluid level in the radiator like notice any difference? Anyway do the compression test if all cylinders are close look at the intake gaskets for a possible leak...you could always have the cooling system pressure tested too and if it doesnt hold pressure chances are its a intake gasket leak that you cant see...most times an intake gasket would leak coolant into the oil
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
