How To Adjust MAF Voltage?
Car: Camaro RS
Engine: 2.8 L
MAF Voltage is too high I don't know how to lower it??
Could anybody tell me how to adjust it?
Thanks Alot!
Thanks Alot!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just curious here, what indications are you getting that tells you your MAF voltage is too high? Are you getting a code 33 or 34? If you are, that indicates that the MAF is registering either too much or too little air through it. BTW, the MAF voltage is not adjustable. Trending Topics
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The tps sensor will also trip that code if it is out of adjustment, check your voltage. Mine will trip the light if it is higher than .62.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
