Throttle body has a cut in it!!!
Old Mar 24, 2001 | 12:02 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Well, yesterday i went investigating my high idle problem. For the longest of time it would idle at 1,000 rpms. I picked up my throttle body cleaner and went to clear out the throttle bores. Well, when i opened the blade i saw what looked like a crack. Then i looked closer and it was cut into the bore. It's rigidy keeping my blades from closeing. My question is, can i just use 2000 grit sand paper and debur the cut? or will that mess something up? I just would hate to buy a new throttle body...but if i have to, then i'll just do that.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 24, 2001 | 01:25 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
For that wear to depelop, the bushings that the shaft rides on must be shot. You may be able to replace the bushings and lightly sand the ridge down, but this may result in too much bypassed air still. It would be a perfect core to trade in on a 52mm tb if you plan to go that route (easiest and cheapest).
I have my old tb ('88) thats in good shape except for the bottom manifold bolts are snapped off in it (if you want to stay @ 48mm). Yours will probably break also when you remove them (coolant does nasty things to them). If you can drill and retap the holes i'll ship it cheap (e-mail me if interested). If your not in a hurry (I need around a week) I could do this for you for a small fee.
I'm not sure if reman'd 52mm come with the bottom piece (iac/coolant manifold) so make sure to check in on this before sending it out. (they may expect you to re-use it)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
